Ana içeriğe geç
GameSir Cyclone 2 Battery Replacement
Neye ihtiyacın var
  1. GameSir Cyclone 2 Battery Replacement, Face Plate: adım 1, 3 resimden 1. GameSir Cyclone 2 Battery Replacement, Face Plate: adım 1, 3 resimden 2. GameSir Cyclone 2 Battery Replacement, Face Plate: adım 1, 3 resimden 3.
    • Flip the controller around so the back part is facing you.
    • Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
    • One of the screws is hidden under the sticker. Use a pair of tweezers to lift the sticker and reveal the screw.
    FixBot'a Sor
    Yorum Ekle
  2. GameSir Cyclone 2 Battery Replacement: adım 2, 1 resimden 1.
    • The screws holding the face plate are of two different lengths:
    • The two longer screws belong to the two top screw sockets on the controller.
    • The five shorter screws belong in the five bottom screw sockets, two per handle, and on in the center of on the controller.
    FixBot'a Sor
    Yorum Ekle
  3. GameSir Cyclone 2 Battery Replacement: adım 3, 2 resimden 1. GameSir Cyclone 2 Battery Replacement: adım 3, 2 resimden 2.
    • Face the controller toward you.
    • Gently lift the face plate off the controller.
    • The d-pad and action buttons will become loose once the face plate is lifted.
    FixBot'a Sor
    Yorum Ekle
  4. GameSir Cyclone 2 Battery Replacement, Joystick Covers: adım 4, 3 resimden 1. GameSir Cyclone 2 Battery Replacement, Joystick Covers: adım 4, 3 resimden 2. GameSir Cyclone 2 Battery Replacement, Joystick Covers: adım 4, 3 resimden 3.
    • Pull both joystick covers straight up to remove them from the controller.
    FixBot'a Sor
    Yorum Ekle
  5. GameSir Cyclone 2 Battery Replacement, Left and Right Bumpers and Triggers: adım 5, 1 resimden 1.
    • Note the bumpers and triggers on the controller.
    FixBot'a Sor
    Yorum Ekle
  6. GameSir Cyclone 2 Battery Replacement: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove two screws on either side of the power button.
    • Remove the assembly that includes the power button and the top bumper buttons.
    FixBot'a Sor
    Yorum Ekle
  7. GameSir Cyclone 2 Battery Replacement: adım 7, 1 resimden 1.
    • Remove the bumpers and triggers from the controller.
    FixBot'a Sor
    Yorum Ekle
  8. GameSir Cyclone 2 Battery Replacement, LED: adım 8, 1 resimden 1.
    • Locate the two black boxes towards the bottom of the controller.
    • Remove these two boxes by pulling them away from the controller. They should snap right off.
    FixBot'a Sor
    Yorum Ekle
  9. GameSir Cyclone 2 Battery Replacement: adım 9, 1 resimden 1.
    • Locate the LED diffusers on either side of the controller face. They are clear, cylindrical strips that help spread light from the LED beneath the black boxes removed in the previous step.
    • Lift the upper ends of each LED diffuser and remove them.
    FixBot'a Sor
    Yorum Ekle
  10. GameSir Cyclone 2 Battery Replacement, Battery: adım 10, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the four screws that secure the LED diffuser tracks.
    • Remove the LED diffuser tracks.
    FixBot'a Sor
    Yorum Ekle
  11. GameSir Cyclone 2 Battery Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the single screw in the center of the motherboard.
    • Remove the motherboard from the controller case.
    FixBot'a Sor
    Yorum Ekle
  12. GameSir Cyclone 2 Battery Replacement: adım 12, 2 resimden 1. GameSir Cyclone 2 Battery Replacement: adım 12, 2 resimden 2.
    • Disconnect the battery connector from the socket on the motherboard.
    • Remove the battery.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
JasmineM
373 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-6, Bowman Fall 2025 UMass Dartmouth, Team 2-6, Bowman Fall 2025 üyesi
UMASSD-BOWMAN-F25S2G6
4 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Which battery is used there. I mean the specs so I can buy it.
Davi Ribeiro - Yanıt Paylaş
Hi @daviribeiro, we don't have the specific battery details, but it uses a 860mAh rechargeable Lithium-ion battery.
Sarah Westberg - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 43
Son 30 gün: 219
Her zaman: 1,358
