Giriş
Follow this guide if you need to remove or replace the joystick covers (also called caps or thumb grips) of your GameSir Cyclone 2 controller.
You may need to replace the joystick covers when they are worn or to customize the appearance of your controller.
Neye ihtiyacın var
Flip the controller around so the back part is facing you.
Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
Pull both joystick covers straight up to remove them from the controller.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
