Giriş
Follow the instructions in this guide to replace the RGB lights in your GameSir Cyclone 2 controller.
Neye ihtiyacın var
Flip the controller around so the back part is facing you.
Use a T6 Torx screwdriver to remove seven screws from the back of the controller.
Pull both joystick covers straight up to remove them from the controller.
Locate the two black boxes towards the bottom of the controller.
Remove these two boxes by pulling them away from the controller. They should snap right off.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Bir başkası bu kılavuzu tamamladı.
