Ana içeriğe geç
GameSir Tarantula Pro Joystick Cover Replacement
Neye ihtiyacın var
  1. GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: adım 1, 3 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: adım 1, 3 resimden 2. GameSir Tarantula Pro Joystick Cover Replacement, Joystick Covers: adım 1, 3 resimden 3.
    • Use the tip of a spudger to remove the rubber screw covers from the backs of the handles and the top edge of the back case.
    • Gently pry up each screw cover and lift it out.
    FixBot'a Sor
    Yorum Ekle
  2. GameSir Tarantula Pro Joystick Cover Replacement: adım 2, 2 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the 4.0 mm screws from the back case.
    • Because the screws are deeply recessed, use a long, thin driver to remove them.
    FixBot'a Sor
    Yorum Ekle
  3. GameSir Tarantula Pro Joystick Cover Replacement: adım 3, 2 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement: adım 3, 2 resimden 2.
    • Slide a spudger around the seam between the top and bottom cases to release the retaining clips.
    • Remove the bottom case.
    FixBot'a Sor
    Yorum Ekle
  4. GameSir Tarantula Pro Joystick Cover Replacement: adım 4, 3 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement: adım 4, 3 resimden 2. GameSir Tarantula Pro Joystick Cover Replacement: adım 4, 3 resimden 3.
    • Use the Phillips #000 screwdriver to remove the nine 4.0 mm screws from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  5. GameSir Tarantula Pro Joystick Cover Replacement: adım 5, 3 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement: adım 5, 3 resimden 2. GameSir Tarantula Pro Joystick Cover Replacement: adım 5, 3 resimden 3.
    • Use the point of a spudger to push on alternating sides of each JST connector to "walk" it out of its socket.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • If that doesn't work, use a pair of tweezers to firmly grip the sides of the connector and pull straight away from the socket. Hold the tweezers closer to the connector to get a better grip.
    • If you're having trouble, try rocking the connector side-to-side to loosen it.
    • If the connector's socket has cutouts, you can insert the arms of a pair of sharp tweezers into the cutouts and gently push the connector out of its socket.
    • Carefully remove the battery from the controller.
    • Avoid bending or puncturing the battery.
    • The battery is secured by double-sided tape, so it may take some work to loosen the adhesive before you can completely remove the battery. Use the iFixit adhesive remover if you have trouble removing the battery.
    FixBot'a Sor
    Yorum Ekle
  6. GameSir Tarantula Pro Joystick Cover Replacement: adım 6, 2 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement: adım 6, 2 resimden 2.
    • Carefully remove the motherboard from the shell.
    • Flip the motherboard over so the joysticks are facing upward.
    FixBot'a Sor
    Yorum Ekle
  7. GameSir Tarantula Pro Joystick Cover Replacement: adım 7, 3 resimden 1. GameSir Tarantula Pro Joystick Cover Replacement: adım 7, 3 resimden 2. GameSir Tarantula Pro Joystick Cover Replacement: adım 7, 3 resimden 3.
    • Remove the joysticks by gently pulling them up and off their mounts.
    • When installing the new joystick covers, press them down onto the joysticks until you hear a click, indicating they are securely locked in place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eduardo Pereira
195 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 34
Son 30 gün: 136
Her zaman: 232
