Ana içeriğe geç
Gardena BS-XL Spring Replacement
knipwim
knipwim ve başka bir katkıda bulunan
En son December 31, 2024 tarihinde güncellendi
15 dakika
Kolay
Topluluk-Katkılı Kılavuz
The Gardena B/S-XL garden shears uses a leaf spring to open the shears when closed. If the spring is broken, you can still use the shears, but it won't open automatically.
This manual will show how to replace this spring when broken.
  1. Gardena BS-XL Spring Replacement, disconnect the blades: adım 1, 1 resimden 1.
    • The bolt holding the 2 blades together is typically fastened with threadlocker from the factory to prevent the bolt from undoing itself when in use.
    • While holding the shears in a vise, undo the T30 bolt holding the 2 blades together.
  2. Gardena BS-XL Spring Replacement, remove the broken spring: adım 2, 3 resimden 1. Gardena BS-XL Spring Replacement, remove the broken spring: adım 2, 3 resimden 2. Gardena BS-XL Spring Replacement, remove the broken spring: adım 2, 3 resimden 3.
    • This step assumes the spring is broken in the middle.
    • Remove the first part of the broken spring from the handle.
    • Pull the blade from the handle.
    • Remove the second part of the broken spring from the handle. If it is stuck, you can use a flathead screwdriver to wriggle it loose.
  3. Gardena BS-XL Spring Replacement, insert the new spring: adım 3, 3 resimden 1. Gardena BS-XL Spring Replacement, insert the new spring: adım 3, 3 resimden 2. Gardena BS-XL Spring Replacement, insert the new spring: adım 3, 3 resimden 3.
    • Slide the new spring into the handle, and make sure there is room for the blade behind it.
    • Slide it in as far as it will go.
    • Push the blade back in until the handle hole aligns with the blade hole. This will put tension on the spring.
  4. Gardena BS-XL Spring Replacement, connect blades: adım 4, 3 resimden 1. Gardena BS-XL Spring Replacement, connect blades: adım 4, 3 resimden 2. Gardena BS-XL Spring Replacement, connect blades: adım 4, 3 resimden 3.
    • Apply some threadlock on the bolt.
    • Align both blades and insert the nut. Screw in the bolt partially.
    • Ensure the spring is level and pushing against the other blade.
    • Fasten the bolt while opening and closing the shears to make sure it is neither to loose or too tight, and also to verify the spring is working correctly.
Bitiş Çizgisi
knipwim
11.502 İtibar
36 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 150
Her zaman: 294
