Ana içeriğe geç
Garmin Avionics Wiring Termination
  1. Garmin Avionics Wiring Termination, Tools needed: adım 1, 1 resimden 1.
    • DMC crimpers with appropriate turret
    • Wire strippers
    • Flush cuts
    • Razor
    • Fine tip sharpie, or label printer for wires
    • Heat gun
  2. Garmin Avionics Wiring Termination, Materials needed: adım 2, 1 resimden 1.
    • Wire
    • Shield braid
    • Heat shrink (2 pieces), at least one piece white
    • Environmental splice
    • Pins
  3. Garmin Avionics Wiring Termination, Wire parts: adım 3, 1 resimden 1.
    • Interior wires- where the signal is passed through
    • Outer layer of insulation
    • Shielding- a braid inside the wire over the interior wires. This protects the signal from interference or interfering with other signals. The shielding is terminated to a ground
  4. Garmin Avionics Wiring Termination, Strip wire: adım 4, 2 resimden 1. Garmin Avionics Wiring Termination, Strip wire: adım 4, 2 resimden 2.
    • Expose about 1.5" of shield by removing outer layer of wire.
  5. Garmin Avionics Wiring Termination, Remove shielding: adım 5, 2 resimden 1. Garmin Avionics Wiring Termination, Remove shielding: adım 5, 2 resimden 2.
    • Remove shielding to expose wires
    • Option 1: unbraid shield and the cut away from wire
    • Option 2: carefully cut shield away without nicking the interior wires
  6. Garmin Avionics Wiring Termination, Cut a shield block: adım 6, 1 resimden 1.
    • Cut a 0.25" long section from outer layer of the wire about 2.5" from the end of the wire.
    • This accomplished with a razor. A new razor will cut more easily through the insulation but can also cut through the shielding. A dull razor is harder to cut with but also more forgiving to mistakes.
    • If the shielding is cut through and the interior wires nicked there is a high potential for a short to ground and that section of wire must be cut off and the wire must be restarted.
  7. Garmin Avionics Wiring Termination, Shielding termination: adım 7, 2 resimden 1. Garmin Avionics Wiring Termination, Shielding termination: adım 7, 2 resimden 2.
    • Insert the environmental splice over the cut shielding block and insert the shield braid into it. The solder ring must go over both the exposed shield and the braid.
    • Insert a piece of heat shrink over the end of the wire where the shield and outer insulation is cut. This will protect the end of the wire
    • Heat the splice and heat-shrink with a heat gun. Ensure the solder flows in the splice soldering the braid to the shield.
  8. Garmin Avionics Wiring Termination, Wire termination: adım 8, 2 resimden 1. Garmin Avionics Wiring Termination, Wire termination: adım 8, 2 resimden 2.
    • Strip wires appropriate length - detailed in next step
    • Crimp terminals to wire
  9. Garmin Avionics Wiring Termination, Wire strip length: adım 9, 3 resimden 1. Garmin Avionics Wiring Termination, Wire strip length: adım 9, 3 resimden 2. Garmin Avionics Wiring Termination, Wire strip length: adım 9, 3 resimden 3.
    • The wire strip length should by just barely longer than the barrel (where the wire goes) of the crimped contact
    • First picture shows a correct termination
    • Second picture shows to long of strip on wire
    • To make sure the wire is stripped long enough the conductor strands should be visible in the witness hole circled in the third picture
  10. Garmin Avionics Wiring Termination, Label wire: adım 10, 1 resimden 1.
    • Add heat-shrink with wire number added to it to identify wire after install
  11. Garmin Avionics Wiring Termination, Install: adım 11, 1 resimden 1.
    • Push pins into connector, the should lock into place and need a special tool for removal
  12. Garmin Avionics Wiring Termination, Shield Termination: adım 12, 1 resimden 1.
    • Crimp ring terminal to shield braid
    • Install ring terminal to designated grounding location. Often the connector back-shell.
    • This step is done last after all wires for a connector are installed and back-shell is assembled on connector. Sometimes a separate ground lug needs to be installed onto the back-shell.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Wieli
2.141 İtibar
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 49
Her zaman: 472
