Ana içeriğe geç
Garmin DriveSmart 50 LMT Battery Replacement
Neye ihtiyacın var
    1. Garmin DriveSmart 50 LMT Battery Replacement, Battery: adım 1, 1 resimden 1.
      • Use a T5 Torx screwdriver to remove the four screws from the bottom case.
      FixBot'a Sor
      Yorum Ekle
    2. Garmin DriveSmart 50 LMT Battery Replacement: adım 2, 2 resimden 1. Garmin DriveSmart 50 LMT Battery Replacement: adım 2, 2 resimden 2.
      • Insert an opening tool into the seam between the top and bottom case.
      • Slide it around the perimeter of the device to release the clips holding them together.
      • Separate the top and bottom of your GPS.
      • Flip the device so that the motherboard and the battery are facing up.
      FixBot'a Sor
      Yorum Ekle
    3. Garmin DriveSmart 50 LMT Battery Replacement: adım 3, 1 resimden 1.
      • Use the angled tweezers to unplug the battery connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    4. Garmin DriveSmart 50 LMT Battery Replacement: adım 4, 1 resimden 1.
      • Use an opening tool or spudger to gently pry the battery out, being careful not to puncture or bend it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Lydia Barrett
463 İtibar
3 adet Kılavuz yazıldı
Ekip
Texas Tech, Team 41-5, Allen Fall 2025 Texas Tech, Team 41-5, Allen Fall 2025 üyesi
TTU-ALLEN-F25S41G5
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 47
Her zaman: 241
