Ana içeriğe geç
Garmin DriveSmart 55 EX Screen Replacement
Neye ihtiyacın var
  1. Garmin DriveSmart 55 EX Screen Replacement, Screen: adım 1, 3 resimden 1. Garmin DriveSmart 55 EX Screen Replacement, Screen: adım 1, 3 resimden 2. Garmin DriveSmart 55 EX Screen Replacement, Screen: adım 1, 3 resimden 3.
    • Use a T5 Torx screwdriver to remove the four 4.2 mm black screws from the back case.
    • Insert the plastic opening tool into the gap between the screen and case, and release the clips along the edges of the device.
    • Use opening picks along the perimeter to keep them separated until you can remove the screen.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin DriveSmart 55 EX Screen Replacement: adım 2, 3 resimden 1. Garmin DriveSmart 55 EX Screen Replacement: adım 2, 3 resimden 2. Garmin DriveSmart 55 EX Screen Replacement: adım 2, 3 resimden 3.
    • Gently separate the screen from the case and place the device flat on the surface.
    • Avoid pulling on the screen too forcefully, as the display ribbon cable is still connected to the motherboard.
    • Use a T5 Torx screwdriver to remove the four 3.8 mm silver screws from the motherboard.
    • Avoid scratching the motherboard when using the screwdriver, as this can damage the device.
    • Gently pry the motherboard up using the plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin DriveSmart 55 EX Screen Replacement: adım 3, 2 resimden 1. Garmin DriveSmart 55 EX Screen Replacement: adım 3, 2 resimden 2.
    • Use your fingers or tweezers to disconnect the battery connector on the underside of the motherboard.
    • Avoid pulling on the cables.
    FixBot'a Sor
    Yorum Ekle
  4. Garmin DriveSmart 55 EX Screen Replacement: adım 4, 3 resimden 1. Garmin DriveSmart 55 EX Screen Replacement: adım 4, 3 resimden 2. Garmin DriveSmart 55 EX Screen Replacement: adım 4, 3 resimden 3.
    • Use a spudger or a clean fingernail to flip up the locking flap on the ZIF connector.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers to gently pull the gold ribbon cable from the socket on the motherboard.
    • Be careful when removing the ribbon cable because it is thin and can tear easily.
    FixBot'a Sor
    Yorum Ekle
  5. Garmin DriveSmart 55 EX Screen Replacement: adım 5, 2 resimden 1. Garmin DriveSmart 55 EX Screen Replacement: adım 5, 2 resimden 2.
    • Insert a spudger or plastic opening tool into the gap between the screen and display frame.
    • Once a corner begins to lift, slowly slide the tool around the edges to release the clips securing them.
    • The screen is glass and if you use too much force it can shatter and crack the screen.
    • Separate the screen from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 108
