Ana içeriğe geç
Garmin Edge 530 Back Cover Replacement
Neye ihtiyacın var
  1. Garmin Edge 530 Back Cover  Replacement, LCD Screen Display: adım 1, 1 resimden 1.
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
  2. Garmin Edge 530 Back Cover  Replacement: adım 2, 3 resimden 1. Garmin Edge 530 Back Cover  Replacement: adım 2, 3 resimden 2. Garmin Edge 530 Back Cover  Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
  3. Garmin Edge 530 Back Cover  Replacement: adım 3, 3 resimden 1. Garmin Edge 530 Back Cover  Replacement: adım 3, 3 resimden 2. Garmin Edge 530 Back Cover  Replacement: adım 3, 3 resimden 3.
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
  4. Garmin Edge 530 Back Cover  Replacement: adım 4, 1 resimden 1.
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
  5. Garmin Edge 530 Back Cover  Replacement, Motherboard: adım 5, 1 resimden 1.
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
  6. Garmin Edge 530 Back Cover  Replacement: adım 6, 1 resimden 1.
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
  7. Garmin Edge 530 Back Cover  Replacement: adım 7, 2 resimden 1. Garmin Edge 530 Back Cover  Replacement: adım 7, 2 resimden 2.
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
  8. Garmin Edge 530 Back Cover  Replacement: adım 8, 3 resimden 1. Garmin Edge 530 Back Cover  Replacement: adım 8, 3 resimden 2. Garmin Edge 530 Back Cover  Replacement: adım 8, 3 resimden 3.
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
  9. Garmin Edge 530 Back Cover  Replacement, Back Cover: adım 9, 1 resimden 1.
    • At this point, you have successfully isolated the battery and back cover. Most Garmin Edge 530 back cover replacement parts come with a battery. If this is the case, simply reassemble with the new part by following this procedure in reverse order.
    • If your replacement part comes without a battery, refer to the battery replacement guide to successfully remove and replace the battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Lainey Merriwether
638 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-1, Hunter Spring 2022 Clemson, Team 2-1, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G1
5 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 125
Her zaman: 3,853
