Ana içeriğe geç
Garmin Edge 530 Battery Replacement
Neye ihtiyacın var
  1. Garmin Edge 530 Battery Replacement, LCD Screen Display: adım 1, 1 resimden 1.
    • Insert the metal spudger between the edge of the device screen and back cover.
    • Begin to pry along the perimeter between the device screen and back cover.
    FixBot'a Sor
    Yorum Ekle
  2. Garmin Edge 530 Battery Replacement: adım 2, 3 resimden 1. Garmin Edge 530 Battery Replacement: adım 2, 3 resimden 2. Garmin Edge 530 Battery Replacement: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Halberd Spudger
    $2.99
    • Use the nylon halberd spudger to lift the edge of the screen and begin separating it from the back cover.
    • Removing the screen can potentially cause the glass to crack and potential injury. Do this carefully.
    FixBot'a Sor
    Yorum Ekle
  3. Garmin Edge 530 Battery Replacement: adım 3, 3 resimden 1. Garmin Edge 530 Battery Replacement: adım 3, 3 resimden 2. Garmin Edge 530 Battery Replacement: adım 3, 3 resimden 3.
    • Peel back the tape holding down the orange ribbon cables with the nylon halberd spudger.
    FixBot'a Sor
    Yorum Ekle
  4. Garmin Edge 530 Battery Replacement: adım 4, 1 resimden 1.
    • Completely detach the screen from the back cover by disconnecting the orange ribbon cables.
    • Be sure to reconnect the orange ribbon cables from the new LCD screen at the original attachment site.
    FixBot'a Sor
    Yorum Ekle
  5. Garmin Edge 530 Battery Replacement, Motherboard: adım 5, 2 resimden 1. Garmin Edge 530 Battery Replacement, Motherboard: adım 5, 2 resimden 2.
    Halberd Spudger
    $2.99
    • Detach the press-fit connector from the motherboard using the nylon halberd spudger.
    • Gently peel back the copper adhesive strip to free the remaining bonding cable.
    FixBot'a Sor
    Yorum Ekle
  6. Garmin Edge 530 Battery Replacement: adım 6, 1 resimden 1.
    • Remove the three 6 mm screws connecting the motherboard to the back panel using the T5 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  7. Garmin Edge 530 Battery Replacement: adım 7, 2 resimden 1. Garmin Edge 530 Battery Replacement: adım 7, 2 resimden 2.
    • Take the motherboard out of the back cover.
    • You will remove the wire harness in the next step.
    FixBot'a Sor
    Yorum Ekle
  8. Garmin Edge 530 Battery Replacement: adım 8, 3 resimden 1. Garmin Edge 530 Battery Replacement: adım 8, 3 resimden 2. Garmin Edge 530 Battery Replacement: adım 8, 3 resimden 3.
    $3.99
    • Remove the wire harness that connects the motherboard to the battery using the angled tweezers by pulling it out of the compartment.
    • Now the motherboard and compartment are separated.
    FixBot'a Sor
    Yorum Ekle
  9. Garmin Edge 530 Battery Replacement, Battery: adım 9, 2 resimden 1. Garmin Edge 530 Battery Replacement, Battery: adım 9, 2 resimden 2.
    Halberd Spudger
    $2.99
    • Use a nylon halberd spudger to pry up the orange ribbon cable connecting the battery to the charging port.
    • Fully remove the orange ribbon cable from the charging port.
    FixBot'a Sor
    Yorum Ekle
  10. Garmin Edge 530 Battery Replacement: adım 10, 3 resimden 1. Garmin Edge 530 Battery Replacement: adım 10, 3 resimden 2. Garmin Edge 530 Battery Replacement: adım 10, 3 resimden 3.
    • Use the nylon halberd spudger to peel the battery from the adhesive holding it into the back case.
    • Gently pry up the edges of the battery.
    • Once the adhesive has been separated from the battery, carefully lift it out of the back case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Lainey Merriwether
644 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 2-1, Hunter Spring 2022 Clemson, Team 2-1, Hunter Spring 2022 üyesi
CLEM-HUNTER-S22S2G1
5 Üyeler
23 adet Kılavuz yazıldı
6Kılavuz Yorumları
how is the screen glued back in?
Peter Gee - Yanıt Paylaş
You might use the T-8000 glue
Andrea Castellani - Yanıt Paylaş
How do those 3 cables get reattached? Do they need to be soldered or are they just pushed back into the black clip?
paulbreslin1983 - Yanıt Paylaş
How do those 3 cables go back in, just push into bracket? Do they need to be soldered?
Why you need motherboard?
Mo L - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 96
Son 30 gün: 476
Her zaman: 31,389
