Ana içeriğe geç
Garmin Fenix 3 Display Assembly Replacement
Neye ihtiyacın var
  1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 1. Garmin Fenix 3 Display Assembly Replacement, Display Assembly: adım 1, 2 resimden 2.
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Display Assembly Replacement: adım 2, 1 resimden 1.
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Display Assembly Replacement: adım 4, 1 resimden 1.
    • Set the watch face aside.
    Hi can i replace only lcd because my sapphire glass is ok
    Drazen Popadic - Yanıt
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Thanks Adam. How do you chgange the glass in a Fenix 3? I can strip the watch down as you have described but not sure how to replace the screen.
Richard Davies-Cooke - Yanıt
I have the same question.
Nicolas Chartier -
How do you make sure ribbon connector is aligned correctly
Steven - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 80
Her zaman: 9,862
