Ana içeriğe geç
Garmin Fenix 3 Motherboard Replacement
Adam Estabrook
Adam Estabrook ve 4 diğer katkıda bulunanlar
En son August 22, 2024 tarihinde güncellendi
5 dakika
Kolay
Even the best electronics die out over time, especially devices used in harsh conditions. This guide will show how to replace the motherboard of your Garmin Fenix 3 if the electronics are showing signs of failure. You will need a T6 Torx screwdriver, a T5 Torx screwdriver, and a spudger.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Fenix 3 Motherboard Replacement, Display Assembly: adım 1, 2 resimden 1. Garmin Fenix 3 Motherboard Replacement, Display Assembly: adım 1, 2 resimden 2.
    • Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
  2. Garmin Fenix 3 Motherboard Replacement: adım 2, 1 resimden 1.
    • Carefully lift the face off the watch base.
    • Do not yank the face. A ribbon connector connects the face and the motherboard, and yanking could result in damage to the motherboard or ribbon.
  3. Garmin Fenix 3 Motherboard Replacement: adım 3, 1 resimden 1.
    • Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
  4. Garmin Fenix 3 Motherboard Replacement: adım 4, 1 resimden 1.
    • Set the watch face aside.
  5. Garmin Fenix 3 Motherboard Replacement, GPS Antenna: adım 5, 1 resimden 1.
    • Locate the antenna, which is located on the motherboard.
  6. Garmin Fenix 3 Motherboard Replacement: adım 6, 1 resimden 1.
    • Carefully remove the antenna, and set it aside.
  7. Garmin Fenix 3 Motherboard Replacement, Motherboard: adım 7, 3 resimden 1. Garmin Fenix 3 Motherboard Replacement, Motherboard: adım 7, 3 resimden 2. Garmin Fenix 3 Motherboard Replacement, Motherboard: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
    • To avoid losing or dropping the screws once they are loose, use tweezers to extract them.
  8. Garmin Fenix 3 Motherboard Replacement: adım 8, 2 resimden 1. Garmin Fenix 3 Motherboard Replacement: adım 8, 2 resimden 2.
    • Lift the watch and turn it over one hand. The motherboard should fall out easily.
    • When reinserting your motherboard, slide it in instead of pressing it. The motherboard must go beneath a lip at the base of the watch body.
  9. Garmin Fenix 3 Motherboard Replacement: adım 9, 1 resimden 1.
    • Using the spudger, separate the motherboard from the battery, which are both held together with a mild adhesive.
  10. Garmin Fenix 3 Motherboard Replacement: adım 10, 1 resimden 1.
    • Motherboard without metal cover
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
18 Yorum
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
Jan Stefan - Yanıt
that's my problem too and i can't find any solution.
Hamidmonti -
How did you remove the metal cover from the moterboard (last picture)
slowrun - Yanıt
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
arnaud.lhote - Yanıt
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
ilija.veselica -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 58
Her zaman: 10,153
