Ana içeriğe geç
Garmin Nuvi 1390LMT Battery Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 1390LMT Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Snap the plastic cover off using a plastic opening tool.
  2. Garmin Nuvi 1390LMT Battery Replacement: adım 2, 2 resimden 1. Garmin Nuvi 1390LMT Battery Replacement: adım 2, 2 resimden 2.
    • Remove the four black 11 mm T5 torx screws.
  3. Garmin Nuvi 1390LMT Battery Replacement: adım 3, 1 resimden 1.
    • Pop the screen cover off with a plastic opening tool.
  4. Garmin Nuvi 1390LMT Battery Replacement: adım 4, 2 resimden 1. Garmin Nuvi 1390LMT Battery Replacement: adım 4, 2 resimden 2.
    • Flip the screen over out of the case.
    • Be sure not to twist or damage the wiring harness connecting the screen to the circuit board.
  5. Garmin Nuvi 1390LMT Battery Replacement: adım 5, 1 resimden 1.
    • Remove the two silver 5 mm T5 torx screws connecting the circuit board to the plastic casing.
  6. Garmin Nuvi 1390LMT Battery Replacement: adım 6, 2 resimden 1. Garmin Nuvi 1390LMT Battery Replacement: adım 6, 2 resimden 2.
    • Flip the circuit board over onto the screen.
  7. Garmin Nuvi 1390LMT Battery Replacement: adım 7, 1 resimden 1.
    • Disconnect the harness between the battery and the circuit board.
  8. Garmin Nuvi 1390LMT Battery Replacement: adım 8, 2 resimden 1. Garmin Nuvi 1390LMT Battery Replacement: adım 8, 2 resimden 2.
    • Peel the battery from the plastic back with a plastic opening tool.
    • It is connected with a glue so be careful.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Trey Ulsh
537 İtibar
3 adet Kılavuz yazıldı
Ekip
Montana Tech, Team 10-4, Shirk Fall 2015 Montana Tech, Team 10-4, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S10G4
5 Üyeler
1Rehber Yorum
Great guide and very informative. Here is a replacement battery that is reasonably priced and it comes with all of the tools needed for installation. It even has a 1 year replacement warranty!
Nuvi 1390 Battery 361-00019-16
Mike - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 4,001
