Ana içeriğe geç
Garmin Nuvi 200w Speaker Replacement
Nick Scharr
Nick Scharr ve 3 diğer katkıda bulunanlar
En son July 20, 2017 tarihinde güncellendi
20 - 30 dakika
Orta
The speaker of the Garmin Nuvi 200W is prone to water damage and may fail over time. Replacing the speaker can make the Nuvi 200W sound new again, at much less cost!
It is important to note, however, that the case and it's internals require very specific screws, that are small and easy to lose. It is recommended that a magnet or tap is used to secure screws after removal. It is also important to gently remove the back cover, as it will be attached to other interior elements. This connection is sensitive and should be treated as such until the guide shows proper disconnection of this particular cable.
Only basic tools are required, such as screw drivers, and opening tools.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Nuvi 200w Speaker Replacement, Rear Cover: adım 1, 3 resimden 1. Garmin Nuvi 200w Speaker Replacement, Rear Cover: adım 1, 3 resimden 2. Garmin Nuvi 200w Speaker Replacement, Rear Cover: adım 1, 3 resimden 3.
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200w Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200w Speaker Replacement: adım 3, 3 resimden 1. Garmin Nuvi 200w Speaker Replacement: adım 3, 3 resimden 2. Garmin Nuvi 200w Speaker Replacement: adım 3, 3 resimden 3.
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200w Speaker Replacement: adım 4, 2 resimden 1. Garmin Nuvi 200w Speaker Replacement: adım 4, 2 resimden 2.
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
  5. Garmin Nuvi 200w Speaker Replacement, Display Assembly: adım 5, 3 resimden 1. Garmin Nuvi 200w Speaker Replacement, Display Assembly: adım 5, 3 resimden 2. Garmin Nuvi 200w Speaker Replacement, Display Assembly: adım 5, 3 resimden 3.
    • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
    • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
    • Slide the orange ribbon cable away from the ZIF connector.
  6. Garmin Nuvi 200w Speaker Replacement, Motherboard: adım 6, 2 resimden 1. Garmin Nuvi 200w Speaker Replacement, Motherboard: adım 6, 2 resimden 2.
    • Using a screw driver, unscrew the four 2mm screws holding the motherboard in place.
    • Gently lift the motherboard away from the rear cover. Take care to not damage the wires or ports that link the motherboard to other components.
  7. Garmin Nuvi 200w Speaker Replacement: adım 7, 3 resimden 1. Garmin Nuvi 200w Speaker Replacement: adım 7, 3 resimden 2. Garmin Nuvi 200w Speaker Replacement: adım 7, 3 resimden 3.
    • Using the black spudger, apply pressure to nudge the plug out of its port.
    • Repeat this process for both ports.
  8. Garmin Nuvi 200w Speaker Replacement, Speaker: adım 8, 3 resimden 1. Garmin Nuvi 200w Speaker Replacement, Speaker: adım 8, 3 resimden 2. Garmin Nuvi 200w Speaker Replacement, Speaker: adım 8, 3 resimden 3.
    • Using the plastic opening tool, carefully apply pressure to lift the speaker up from the back cover.
    • There may be some type of adhesive around the edges of the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nick Scharr
222 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 UMass Dartmouth, Team S5-G4, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S5G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 192
