Ana içeriğe geç
Garmin Nuvi 2455LMT Mother Board Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 2455LMT Mother Board Replacement, Back Panel Assembly: adım 1, 1 resimden 1.
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Mother Board Replacement: adım 2, 2 resimden 1. Garmin Nuvi 2455LMT Mother Board Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
  3. Garmin Nuvi 2455LMT Mother Board Replacement: adım 3, 3 resimden 1. Garmin Nuvi 2455LMT Mother Board Replacement: adım 3, 3 resimden 2. Garmin Nuvi 2455LMT Mother Board Replacement: adım 3, 3 resimden 3.
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
  4. Garmin Nuvi 2455LMT Mother Board Replacement, Mother Board: adım 4, 1 resimden 1.
    • Remove the two 1.0mm 04# Torx screws from the mother board assembly
    • One screw can be found directly to the right of the battery and one screw can be found behind the orange band.
    • Hold the GPS with a free hand to ensure stability.
  5. Garmin Nuvi 2455LMT Mother Board Replacement: adım 5, 2 resimden 1. Garmin Nuvi 2455LMT Mother Board Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Place the screen portion of the GPS face down.
    • Remove the mother board from the plastic back panel.
    • Disconnect the battery with tweezers by gripping the white socket displayed in the photo. Wiggle the white socket out of the mother board.
  6. Garmin Nuvi 2455LMT Mother Board Replacement: adım 6, 1 resimden 1.
    • Use a soldering tool to de-solder the connection to the motherboard. Refer to the iFixit Soldering guide to see how
Sonuç
Nathaniel Williams
264 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 2-3, Blackwell Fall 2016 USF Tampa, Team 2-3, Blackwell Fall 2016 üyesi
USFT-BLACKWELL-F16S2G3
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 572
