Ana içeriğe geç
Garmin Nuvi 2589LMT Power Button Replacement
Adam Ferraro
Adam Ferraro ve 2 diğer katkıda bulunanlar
En son May 16, 2024 tarihinde güncellendi
15 - 20 dakika
Kolay
Tutarsız Görseller
If your power button is not responding, use this guide to replace a defective power button on your Garmin NUVI 2589LMT device. Replacing the power button should fix any response issues you are experiencing with the button, but if it does not you may be experiencing a motherboard issue.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Garmin Nuvi 2589LMT Power Button Replacement, Back Panel Assembly: adım 1, 1 resimden 1.
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Power Button Replacement: adım 2, 2 resimden 1. Garmin Nuvi 2589LMT Power Button Replacement: adım 2, 2 resimden 2.
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Power Button Replacement, Power Button: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    $3.99
    • Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
  4. Garmin Nuvi 2589LMT Power Button Replacement: adım 4, 1 resimden 1.
    • Using the angled tweezers, grab the microphone wires and gently pull to remove the microphone from the device.
  5. Garmin Nuvi 2589LMT Power Button Replacement: adım 5, 1 resimden 1.
    • Using the T5 Torx Screwdriver, remove all 4 of the 4.0 mm screws from the motherboard.
  6. Garmin Nuvi 2589LMT Power Button Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tools gently pry the motherboard away from the case.
    • There is no need to desolder any connections because the motherboard only needs to be moved out of the way enough to get to the button.
  7. Garmin Nuvi 2589LMT Power Button Replacement: adım 7, 1 resimden 1.
    • Using tweezers, lift the button out of its socket.
Sonuç
Adam Ferraro
947 İtibar
8 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-2, Nance Fall 2016 USF Tampa, Team 1-2, Nance Fall 2016 üyesi
USFT-NANCE-F16S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,127
