Ana içeriğe geç
Garmin Nuvi 260W Screen Replacement
Hunter Johnson
Hunter Johnson ve 3 diğer katkıda bulunanlar
En son May 25, 2018 tarihinde güncellendi
8 dakika
Çok kolay
This device can be identified utilizing the criterion on the device page. When replacing the screen, be sure to set aside the following tools: T5 Torx screwdriver and plastic opening tool.
Neye ihtiyacın var
Aletler
  1. Garmin Nuvi 260W Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Carefully remove model/serial number sticker.
  2. Garmin Nuvi 260W Screen Replacement: adım 2, 1 resimden 1.
    • Remove two 4mm T5 Torx screws located under the sticker.
  3. Garmin Nuvi 260W Screen Replacement: adım 3, 2 resimden 1. Garmin Nuvi 260W Screen Replacement: adım 3, 2 resimden 2.
    • Once the screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
  4. Garmin Nuvi 260W Screen Replacement: adım 4, 1 resimden 1.
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
  5. Garmin Nuvi 260W Screen Replacement: adım 5, 1 resimden 1.
    • Use a plastic opening tool to loosen the three clips located on the top of the screen encasing to a position that loosens the hold on the screen.
  6. Garmin Nuvi 260W Screen Replacement: adım 6, 1 resimden 1.
    • Use a plastic opening tool to loosen the two clips on the short sides of the Nuvi screen encasing to a position that allows the removal of the screen.
Sonuç
Hunter Johnson
327 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G5, Harley Spring 2018 IUPUI, Team S3-G5, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S3G5
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 334
