Ana içeriğe geç
Garmin Nuvi 56LMT Speaker Replacement
Neye ihtiyacın var
  1. Garmin Nuvi 56LMT Speaker Replacement, Speaker: adım 1, 1 resimden 1.
    • Power off you Garmin Nuvi before disassembling.
    • Use the T5 torx screwdriver to remove the four 11.0 mm screws.
  2. Garmin Nuvi 56LMT Speaker Replacement: adım 2, 2 resimden 1. Garmin Nuvi 56LMT Speaker Replacement: adım 2, 2 resimden 2.
    • locate the crevice between the front and back panel.
    • Use the plastic opening tool to wedge the device open.
    • Carefully disconnect the ribbon from the ZIF connector.
  3. Garmin Nuvi 56LMT Speaker Replacement: adım 3, 2 resimden 1. Garmin Nuvi 56LMT Speaker Replacement: adım 3, 2 resimden 2.
    • Locate the two 5.0 mm screws and use the T5 Torx screwdriver to remove them.
    • These screws are easily lost so keep track of them.
    • Once the screws are removed flip the motherboard over and locate the blue (+) and black (-) wires connected to the speaker.
  4. Garmin Nuvi 56LMT Speaker Replacement: adım 4, 2 resimden 1. Garmin Nuvi 56LMT Speaker Replacement: adım 4, 2 resimden 2.
    • Use the crimping tool to cut the wires from the motherboard.
    • Use plastic opening tool or fingers to remove the speaker.
  5. Garmin Nuvi 56LMT Speaker Replacement: adım 5, 1 resimden 1.
Sonuç
Dustin Saxon
228 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S3-G5, Nance Fall 2017 USF Tampa, Team S3-G5, Nance Fall 2017 üyesi
USFT-NANCE-F17S3G5
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 122
