Ana içeriğe geç
Garmin Rino 700 Screen Replacement
Neye ihtiyacın var
  1. Garmin Rino 700 Screen Replacement, Battery Disconnect: adım 1, 1 resimden 1.
    • Flip the Garmin Rino 700 over so that the underside is facing up.
    • Using the TR6 Torx Security screwdriver, remove the six 9.5 mm screws on the backside of the device.
  2. Garmin Rino 700 Screen Replacement: adım 2, 2 resimden 1. Garmin Rino 700 Screen Replacement: adım 2, 2 resimden 2.
    • Remove the battery cover and set it to the side.
  3. Garmin Rino 700 Screen Replacement: adım 3, 2 resimden 1. Garmin Rino 700 Screen Replacement: adım 3, 2 resimden 2.
    • Use the spudger to disconnect the battery wire port from the motherboard.
  4. Garmin Rino 700 Screen Replacement, Motherboard: adım 4, 2 resimden 1. Garmin Rino 700 Screen Replacement, Motherboard: adım 4, 2 resimden 2.
    • Using the T5 Torx screwdriver, remove the two 6.4 mm screws on the motherboard.
  5. Garmin Rino 700 Screen Replacement: adım 5, 3 resimden 1. Garmin Rino 700 Screen Replacement: adım 5, 3 resimden 2. Garmin Rino 700 Screen Replacement: adım 5, 3 resimden 3.
    • Using the nylon spudger, lift the motherboard out of its position.
    • Slide the motherboard out of the front panel of the device.
    • Carefully disconnect the motherboard from the panel and remove it out of the device.
  6. Garmin Rino 700 Screen Replacement, Screen: adım 6, 3 resimden 1. Garmin Rino 700 Screen Replacement, Screen: adım 6, 3 resimden 2. Garmin Rino 700 Screen Replacement, Screen: adım 6, 3 resimden 3.
    • Carefully detach the screen at the bottom connections using your hands to reveal the ribbon connection.
    • For a guide on disconnecting and reconnecting the Zero Insertion Force (ZIF) connectors, please visit this guide.
Sonuç
Abigail Dugan
512 İtibar
5 adet Kılavuz yazıldı
Ekip
Clemson, Team 5-5, Hunter Fall 2021 Clemson, Team 5-5, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S5G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 362
