Ana içeriğe geç
Garmin STRIKER 4 Digital Display Replacement
Kylie Buchanan
Kylie Buchanan ve 3 diğer katkıda bulunanlar
En son December 22, 2023 tarihinde güncellendi
5 - 7 dakika
Kolay
If you need to replace the Garmin STRIKER 4 digital display, access it with this guide. Some reasons you may be replacing the screen include dead pixels in the screen or the screen not turning on at all. Be careful when prying away the old screen to avoid any further damage to the casing.
Neye ihtiyacın var
Aletler
  1. Garmin STRIKER 4 Digital Display Replacement, Backing: adım 1, 3 resimden 1. Garmin STRIKER 4 Digital Display Replacement, Backing: adım 1, 3 resimden 2. Garmin STRIKER 4 Digital Display Replacement, Backing: adım 1, 3 resimden 3.
    • Flip the device so the back is facing up.
  2. Garmin STRIKER 4 Digital Display Replacement: adım 2, 3 resimden 1. Garmin STRIKER 4 Digital Display Replacement: adım 2, 3 resimden 2. Garmin STRIKER 4 Digital Display Replacement: adım 2, 3 resimden 3.
    • Remove all six 6 mm screws using a Phillips #0 screwdriver.
    • Detach and flip the backside to open the device.
  3. Garmin STRIKER 4 Digital Display Replacement, Motherboard: adım 3, 2 resimden 1. Garmin STRIKER 4 Digital Display Replacement, Motherboard: adım 3, 2 resimden 2.
    • Slide out the screen cable from the motherboard using the iFixit opening tool or your fingernail.
    • Remove the motherboard from the device.
  4. Garmin STRIKER 4 Digital Display Replacement, Digital Display: adım 4, 3 resimden 1. Garmin STRIKER 4 Digital Display Replacement, Digital Display: adım 4, 3 resimden 2. Garmin STRIKER 4 Digital Display Replacement, Digital Display: adım 4, 3 resimden 3.
    • Use the iFixit opening tool to gently lift the screen from the casing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kylie Buchanan
103 İtibar
1 Kılavuz yazıldı
Ekip
Utah Tech University, Team 1-5, McMurrin Fall 2023 Utah Tech University, Team 1-5, McMurrin Fall 2023 üyesi
UTAHTECH-MCMURRIN-F23S1G5
3 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 243
