Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
Gently pull the battery cable connector from its socket on the motherboard.
The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Remove the two #00 Phillips screws securing the battery to the rear case assembly.
Use a plastic opening tool to peel back the battery bracket.
Cautiously grasp the battery and lift it out of the device.
Carefully heat and desolder the speaker lead wires from the back of each individual speaker.
Use the flat edge of a spudger to pry each speaker from its housing in the rear case assembly.
