Ana içeriğe geç
Garmin StreetPilot c330 Speakers Replacement
Neye ihtiyacın var
  1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: adım 1, 3 resimden 1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: adım 1, 3 resimden 2. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: adım 1, 3 resimden 3.
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Speakers Replacement: adım 2, 3 resimden 1. Garmin StreetPilot c330 Speakers Replacement: adım 2, 3 resimden 2. Garmin StreetPilot c330 Speakers Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Speakers Replacement: adım 3, 2 resimden 1. Garmin StreetPilot c330 Speakers Replacement: adım 3, 2 resimden 2.
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Speakers Replacement: adım 4, 3 resimden 1. Garmin StreetPilot c330 Speakers Replacement: adım 4, 3 resimden 2. Garmin StreetPilot c330 Speakers Replacement: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Speakers Replacement: adım 5, 1 resimden 1.
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Speakers Replacement, Battery: adım 6, 3 resimden 1. Garmin StreetPilot c330 Speakers Replacement, Battery: adım 6, 3 resimden 2. Garmin StreetPilot c330 Speakers Replacement, Battery: adım 6, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Speakers Replacement: adım 7, 3 resimden 1. Garmin StreetPilot c330 Speakers Replacement: adım 7, 3 resimden 2. Garmin StreetPilot c330 Speakers Replacement: adım 7, 3 resimden 3.
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
  8. Garmin StreetPilot c330 Speakers Replacement, Speakers: adım 8, 2 resimden 1. Garmin StreetPilot c330 Speakers Replacement, Speakers: adım 8, 2 resimden 2.
    • Carefully use the spudger to pry the speakers from the outer casing.
    • Once removed, you may use a soldering iron to remove the wires from the speakers.
Sonuç
Michael
107 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010 üyesi
CPSU-MANESS-F10S22G1
3 Üyeler
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 1,744
