Ana içeriğe geç
Garmin Vívoactive 4 Watch Band Replacement
Neye ihtiyacın var
  1. Garmin Vívoactive 4 Watch Band Replacement, Watch Band: adım 1, 1 resimden 1.
    • Flip the watch on its back to reveal the watch band connection pins.
  2. Garmin Vívoactive 4 Watch Band Replacement, Remove Bands: adım 2, 3 resimden 1. Garmin Vívoactive 4 Watch Band Replacement, Remove Bands: adım 2, 3 resimden 2. Garmin Vívoactive 4 Watch Band Replacement, Remove Bands: adım 2, 3 resimden 3.
    • Wedge your fingernail or the tip of a spudger underneath the watch band's small metal pin.
    • Push on the pin to release the strap from it's hinge.
    • Pull the strap away from the watch to disconnect it.
    • The strap will not pull away if the pin isn't fully pushed in.
  3. Garmin Vívoactive 4 Watch Band Replacement: adım 3, 1 resimden 1.
    • With both straps removed, a new replacement watch band may be inserted.
Sonuç
Bryan Chavez
380 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Petersen Fall 2023 UMass Dartmouth, Team 1-3, Petersen Fall 2023 üyesi
UMASSD-PETERSEN-F23S1G3
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 553
