Ana içeriğe geç
Gateway KAV60 LT2016U WiFi Card Replacement
Lydia Benjock
Lydia Benjock ve 8 diğer katkıda bulunanlar
En son November 8, 2018 tarihinde güncellendi
Tahmin yok
Orta
Daha İyi Resimler Gerekli
Daha Fazla Görsel Gerekli
The WiFi card can be replaced once you've opened up your computer.
Neye ihtiyacın var
Aletler
  1. Gateway KAV60 LT2016U WiFi Card Replacement, Battery: adım 1, 3 resimden 1. Gateway KAV60 LT2016U WiFi Card Replacement, Battery: adım 1, 3 resimden 2. Gateway KAV60 LT2016U WiFi Card Replacement, Battery: adım 1, 3 resimden 3.
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U WiFi Card Replacement, Upper Cover: adım 2, 1 resimden 1.
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U WiFi Card Replacement: adım 3, 2 resimden 1. Gateway KAV60 LT2016U WiFi Card Replacement: adım 3, 2 resimden 2.
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U WiFi Card Replacement: adım 4, 3 resimden 1. Gateway KAV60 LT2016U WiFi Card Replacement: adım 4, 3 resimden 2. Gateway KAV60 LT2016U WiFi Card Replacement: adım 4, 3 resimden 3.
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U WiFi Card Replacement: adım 5, 1 resimden 1.
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U WiFi Card Replacement: adım 6, 2 resimden 1. Gateway KAV60 LT2016U WiFi Card Replacement: adım 6, 2 resimden 2.
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
  7. Gateway KAV60 LT2016U WiFi Card Replacement, WiFi Card: adım 7, 2 resimden 1. Gateway KAV60 LT2016U WiFi Card Replacement, WiFi Card: adım 7, 2 resimden 2.
    • The WiFi card is shown here.
    • Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
  8. Gateway KAV60 LT2016U WiFi Card Replacement: adım 8, 2 resimden 1. Gateway KAV60 LT2016U WiFi Card Replacement: adım 8, 2 resimden 2.
    • Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Lydia Benjock
1.216 İtibar
10 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 üyesi
CLEM-BENSON-F13S14G3
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,536
