Ana içeriğe geç
Gateway LT2514u Battery Replacement
Brian Garver
Brian Garver ve 2 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
10 saniye
Çok kolay
This guide will walk you through the process of replacing a dead or dying battery in a Gateway LT2514u.
Neye ihtiyacın var
Aletler
  1. Gateway LT2514u Battery Replacement, Battery: adım 1, 2 resimden 1. Gateway LT2514u Battery Replacement, Battery: adım 1, 2 resimden 2.
    • With the netbook's lid closed, flip it over and slide the latch on the upper left hand side of the netbook to the left.
    • You should see an orange indicator when the battery is unlocked.
  2. Gateway LT2514u Battery Replacement: adım 2, 2 resimden 1. Gateway LT2514u Battery Replacement: adım 2, 2 resimden 2.
    • In the upper right-hand corner of the netbook, slide and hold the switch to the right.
    • Use your other hand to slide out the battery.
    • If the release switch in the upper right-hand area is missing, you can still remove the battery by following Step 3. Otherwise, skip it.
  3. Gateway LT2514u Battery Replacement: adım 3, 3 resimden 1. Gateway LT2514u Battery Replacement: adım 3, 3 resimden 2. Gateway LT2514u Battery Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • If the release switch in the upper right-hand area is missing, insert a slender tool (we used tweezers) into the left side of the smaller hole.
    • Slide and hold the tweezers to the right and use your other hand to slide the battery out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brian Garver
839 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-2, Sullivan Fall 2016 USF Tampa, Team 3-2, Sullivan Fall 2016 üyesi
USFT-SULLIVAN-F16S3G2
3 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 355
