Ana içeriğe geç
Gateway M-2626u RAM Replacement
  1. Gateway M-2626u RAM  Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u RAM  Replacement: adım 2, 3 resimden 1. Gateway M-2626u RAM  Replacement: adım 2, 3 resimden 2. Gateway M-2626u RAM  Replacement: adım 2, 3 resimden 3.
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u RAM  Replacement, Back Panel: adım 3, 2 resimden 1. Gateway M-2626u RAM  Replacement, Back Panel: adım 3, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  4. Gateway M-2626u RAM  Replacement: adım 4, 2 resimden 1. Gateway M-2626u RAM  Replacement: adım 4, 2 resimden 2.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
  5. Gateway M-2626u RAM  Replacement, RAM: adım 5, 1 resimden 1.
    • Remember to always remove or disconnect the battery!
    • Push outwards on the metal tab to unlock the RAM stick from its position.
  6. Gateway M-2626u RAM  Replacement: adım 6, 2 resimden 1. Gateway M-2626u RAM  Replacement: adım 6, 2 resimden 2.
    • Lift up and remove the RAM from the device.
    • Follow the same steps to remove the second RAM stick from your device.
Sonuç
Tanya Jain
317 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G2, Peak Spring 2018 UMass Dartmouth, Team S3-G2, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G2
2 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 112
