Ana içeriğe geç
Gateway NE56R Series Disassembly
Neye ihtiyacın var
  1. Gateway NE56R Series Disassembly, Remove hard drive cover: adım 1, 2 resimden 1. Gateway NE56R Series Disassembly, Remove hard drive cover: adım 1, 2 resimden 2.
    • Remove the two Philips screws securing the hard drive cover to the base.
    • Pry the hard drive cover off with a spudger.
  2. Gateway NE56R Series Disassembly, Remove hard drive caddy: adım 2, 1 resimden 1.
    • With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
  3. Gateway NE56R Series Disassembly, Remove hard drive: adım 3, 1 resimden 1.
    • This step is unnecessary if you are only taking the hard drive out for testing purposes or are removing the motherboard.
    • Remove the four screws securing the hard drive to the caddy.
    • Push the clips away from each other that are holding the RAM sticks. The RAM will then pop upwards. At this point, you can pull the stick out. Repeat for the second stick if applicable.
  4. Gateway NE56R Series Disassembly, Remove keyboard: adım 5, 3 resimden 1. Gateway NE56R Series Disassembly, Remove keyboard: adım 5, 3 resimden 2. Gateway NE56R Series Disassembly, Remove keyboard: adım 5, 3 resimden 3.
    • The keyboard has no screws to remove.
    • Use a fine spudger to push all six keyboard tabs. On the first, you'll have to use a bit of prying to get under the keyboard. After that, get your fingernail under the keyboard, and pull gently as you go along the keyboard using the spudger to pop the other clips.
    • There is one un-pushable clip on each side of the keyboard. Don't try to push them. Instead, once you get the top of the keyboard up, pull the keyboard out of the clips.
    • Gently push each side of the locking connector's lock towards the screen, and then pull the now-loose keyboard cable out. Set the keyboard aside.
    • Gently push each side of the power button locking connector towards the screen, and then pull the cable out.
  5. Gateway NE56R Series Disassembly, Remove palmrest: adım 6, 2 resimden 1. Gateway NE56R Series Disassembly, Remove palmrest: adım 6, 2 resimden 2.
    • Flip the laptop over again.
    • Remove the seventeen Philips M2.5x8 screws securing the palmrest.
    • Remove the two silver Philips M2.5x6 screws securing the palmrest.
    • Break out the Philips #0 bit, and remove the three silver Philips M2 screws securing the palmrest.
    • Use a spudger to separate the palmrest from the base.
    • Slide the optical drive out.
    • Remove the wireless antenna connectors, and then the wireless card.
    One more Philips M2.5x8 screw next to the orange battery switch that isn’t circled
    Bryan Remely - Yanıt
  6. Gateway NE56R Series Disassembly, Remove motherboard: adım 7, 1 resimden 1.
    • Back with the Philips #1 bit, remove the two silver M2.5x6 Philips screws.
    • Remove all cables from the motherboard, including pulling out the wireless antenna from its hole.
    • Flip the motherboard up. The DC jack is still connected to the board, so don't tug the board away just yet.
  7. Gateway NE56R Series Disassembly, Unplug the DC jack: adım 8, 1 resimden 1.
    • Pull back on the DC jack plug to remove it. Now you may remove the motherboard and put the rest of the laptop aside.
    I couldn’t get the jack plug out without using the metal spudger to push the pins in and out.
    This style of little plugs can be a PITA no matter what they are in! But, using a spudger is the best way I’ve found to get these un-plugged - but best to use a plastic tool. Metal tools in this capacity run the risk of damaging something.
    Steve Palacios -
  8. Gateway NE56R Series Disassembly, Remove heatsink: adım 9, 1 resimden 1.
    • Remove the four screws securing the heatsink to the motherboard.
    • Remove the black tape securing the heatsink to the fan, and now the heatsink will be free.
  9. Gateway NE56R Series Disassembly, Remove fan: adım 10, 1 resimden 1.
    • Remove the three screws securing the fan to the motherboard.
    • Remove the fan connector from the motherboard, and then remove the fan.
  10. Gateway NE56R Series Disassembly, Remove CPU: adım 11, 1 resimden 1.
    • Turn the CPU socket screw counterclockwise to release the CPU, and lift the CPU out of the socket.
  11. Gateway NE56R Series Disassembly, Remove speakers: adım 12, 1 resimden 1.
    • Remove each of the screws securing the left and right speakers, and remove the speakers.
  12. Gateway NE56R Series Disassembly, Remove LCD assembly: adım 13, 1 resimden 1.
    • Remove each of the screws securing the hinges to the base, and then lift the assembly upwards to remove it.
  13. Gateway NE56R Series Disassembly, Remove DC jack & USB port board: adım 14, 1 resimden 1.
    • At this point, you may simply pull upwards on the DC jack to remove it.
    • The USB port board is secured by a single M2x3 Philips screw. You may remove this screw and pull the board by its cable upwards.
    • The cable is attached to the base with adhesive.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Joseph Sctbunio
7.578 İtibar
42 adet Kılavuz yazıldı
2Kılavuz Yorumları
What about the GPU, is it built in, bc i have this and need to upgrade ir for windows 11.
Eclipsesion - Yanıt
In this model, the GPU is integrated inside the CPU (it's an
Intel integrated HD3000 iGPU).
These kinds of GPUs are not suitable for gaming and are designed for office/work purposes.
These are low-profile GPUs optimized for battery life.
This kind of integrated GPU might already works on Windows 11 if you try the latest official 64 bit driver.
It works on windows 10 but as stated on the Intel's website it's been a while support for this GPU is abandonned and the driver is officialy built for Windows 8.1 :
https://www.intel.fr/content/www/fr/fr/s...
Brendan -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 13
Son 30 gün: 54
Her zaman: 6,871
