Ana içeriğe geç
Gateway NV55C49u RAM Replacement
  1. Gateway NV55C49u RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Flip the laptop bottom side up.
  2. Gateway NV55C49u RAM Replacement: adım 2, 1 resimden 1.
    • Slide the battery lock to show the red background.
  3. Gateway NV55C49u RAM Replacement: adım 3, 2 resimden 1. Gateway NV55C49u RAM Replacement: adım 3, 2 resimden 2.
    • Push the battery slider to the other side. This will automatically eject the battery.
    • You can now remove the battery.
  4. Gateway NV55C49u RAM Replacement: adım 4, 1 resimden 1.
    • Remove the two 6.0mm Phillips #00 screws from the back cover.
  5. Gateway NV55C49u RAM Replacement: adım 5, 3 resimden 1. Gateway NV55C49u RAM Replacement: adım 5, 3 resimden 2. Gateway NV55C49u RAM Replacement: adım 5, 3 resimden 3.
    • Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
  6. Gateway NV55C49u RAM Replacement: adım 6, 2 resimden 1. Gateway NV55C49u RAM Replacement: adım 6, 2 resimden 2.
    • Hold back the plastic that protects the RAM so you can access the clips underneath.
    • Gently push the holding clips outwards. The RAM will angle itself upwards.
    • Gently remove the RAM from the laptop
    • Make sure not to touch any part of the RAM except the sides.
    • When reassembling, insert the RAM into the connector, and then push it down until the clips lock it into place
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matthew
385 İtibar
2 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 186
