Ana içeriğe geç
General Electric Telephone 2-9710A 3V Headset Battery Replacement
Norberto Sanchez
Norberto Sanchez ve 8 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
15 - 30 dakika
Orta
Öğrenci İş Başında
Use this guide to replace the internal battery of the handset
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. General Electric Telephone 2-9710A 3V Headset Battery Replacement, Phone Cord: adım 1, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement, Phone Cord: adım 1, 2 resimden 2.
    • Unplug the device before proceeding.
    • Using a plastic opening tool, remove the phone cord from the phone jack at the base of the headset.
    • To release the cable, gently press down on the top plastic tab of the connector.
  2. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 2, 3 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 2, 3 resimden 2. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 2, 3 resimden 3.
    • Remove the 7.5 mm screw.
    • Remove the screw cap.
    • Pull up the phone cord to remove it from the base.
  3. General Electric Telephone 2-9710A 3V Headset Battery Replacement, General Electric Telephone 2-9710A Handset: adım 3, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement, General Electric Telephone 2-9710A Handset: adım 3, 2 resimden 2.
    • Remove the plastic cover with a plastic opening tool by gently sliding the tool underneath the plastic and pry the cover off.
  4. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 4, 1 resimden 1.
    • Remove the paper with a plastic opening tool by gently sliding the tool underneath and prying the paper away from the phone.
  5. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 5, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 5, 2 resimden 2.
    • Remove the rubber stopper with a plastic opening tool by gently sliding the tool underneath and pry away from the phone.
  6. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 6, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 6, 2 resimden 2.
    • Remove the two 2.1 mm screws with a Phillips #1 screwdriver.
  7. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 7, 1 resimden 1.
    • Pull apart the handset by pulling the top shell away from the other half of the phone.
  8. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 8, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 8, 2 resimden 2.
    • Remove 3 screws attaching the motherboard to shell.
    • Remove the 13 mm screw with a Philips #1 screwdriver.
    • Remove the two 13 mm screws with washers with a Philips #1 screwdriver.
  9. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 9, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 9, 2 resimden 2.
    • Slide the phone jack out from the shell by gently lifting up the female phone jack connector.
  10. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 10, 1 resimden 1.
    • Without removing the motherboard completely, pull up slightly and pivot the motherboard out of the shell.
    • Be careful not to pull the connectors out.
  11. General Electric Telephone 2-9710A 3V Headset Battery Replacement, 3V Headset Battery: adım 11, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use tweezers to apply pressure on battery holder tabs.
    • Apply pressure directly on battery holder to slide it through the shell.
    • Battery is going to slide through the bottom.
  12. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 12, 2 resimden 1. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 12, 2 resimden 2.
    • Lift tabs on the side of the holder by putting your fingers directly on the tab to pull it apart.
    • While holding the battery, remove it from the holder.
  13. General Electric Telephone 2-9710A 3V Headset Battery Replacement: adım 13, 1 resimden 1.
    • Now insert the new battery.
    • Ensure that the positive side of the battery is facing the tabs.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Norberto Sanchez
70 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 16-59, Forte Fall 2012 Cal Poly, Team 16-59, Forte Fall 2012 üyesi
CPSU-FORTE-F12S16G59
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 1,349
