Ana içeriğe geç
Giant Reign 2 Rear Shock Replacement
Andrew Krasts
Andrew Krasts ve 7 diğer katkıda bulunanlar
En son January 3, 2023 tarihinde güncellendi
10 - 20 dakika
Orta
İşlem Görüntüleri
Daha Fazla Görsel Gerekli
Use this guide to learn how to replace the rear shock on your Giant Reign 2 Bicycle.
The rear shock is another term for the rear suspension of a bicycle, and it's used to hold the back wheel stable. It also helps the rider keep control, assists with keeping the bike touching the ground, and aids with mitigating or absorbing any strong impacts. If it fails, the result could be the bicycle malfunctioning and the owner of the bicycle being injured.
Some symptoms of a rear shock's need for replacement are looseness, leaking air, or stiffness when steering. Generally, its recommended that both the rear and front shocks be replaced every six to twelve months, especially if a person is relatively active in bicycling activities.
  1. Giant Reign 2 Rear Shock Replacement, Rear Shock: adım 1, 1 resimden 1.
    • Orient the bike upside down.
  2. Giant Reign 2 Rear Shock Replacement: adım 2, 1 resimden 1.
    • Remove the 10mm screw and take the bash guard off of the frame.
  3. Giant Reign 2 Rear Shock Replacement: adım 3, 1 resimden 1.
    • Remove the 65mm screw that connects the bottom of the shock to the frame.
    • Use a wrench to hold the other side.
  4. Giant Reign 2 Rear Shock Replacement: adım 4, 1 resimden 1.
    • Remove the 40mm screw that connects the shock to the link arm of the suspension.
  5. Giant Reign 2 Rear Shock Replacement: adım 5, 2 resimden 1. Giant Reign 2 Rear Shock Replacement: adım 5, 2 resimden 2.
    • Push the shock out of the brackets mounting it to the frame and suspension arm.
    • This may require some force and slight wiggling from side to side.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Krasts
302 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-14, Amido Fall 2012 Cal Poly, Team 9-14, Amido Fall 2012 üyesi
CPSU-AMIDO-F12S9G14
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Which valve stem is the one to put air into the shock there's one on the bottom one on top and adjustment knob right next to the top one
Ron Hobson - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 40
Her zaman: 5,076
