Ana içeriğe geç
Gigabyte P34G Hard Drive Replacement
Neye ihtiyacın var
  1. Gigabyte P34G Hard Drive Replacement, Hard Drive: adım 1, 1 resimden 1.
    • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
    • There are three different sized screws.
    • 1x 9.8mm Screw
    • 8x 5.6mm Screws
    • 6x 5.0mm Screws
    • Divide the screws by size and save them in a safe space for reassembly later.
    FixBot'a Sor
    Yorum Ekle
  2. Gigabyte P34G Hard Drive Replacement: adım 2, 2 resimden 1. Gigabyte P34G Hard Drive Replacement: adım 2, 2 resimden 2.
    • Carefully peel back the two pieces of black tape holding down the cord.
    • Pull the marked tab straight up away from the board to disconnect the hard drive from the board.
    FixBot'a Sor
    Yorum Ekle
  3. Gigabyte P34G Hard Drive Replacement: adım 3, 1 resimden 1.
    • Carefully lift the hard drive for removal.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
yeunghayden
841 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-1, Regan Spring 2015 Cal Poly, Team 8-1, Regan Spring 2015 üyesi
CPSU-REGAN-S15S8G1
5 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
Hi.
Can you please show me how to remove the back cover on the gigabyte sabre 17 laptop?
Need to change the hdd but cannot open the back.
Thank you.
Rizwan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 29
Her zaman: 3,858
