Ana içeriğe geç
GoPro Hero Motherboard Replacement
Zoe Tuggle
Zoe Tuggle ve 4 diğer katkıda bulunanlar
En son May 26, 2021 tarihinde güncellendi
Tahmin yok
Orta
İşlem Görüntüleri
Daha iyi giriş
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. GoPro Hero Motherboard Replacement, Casing: adım 1, 1 resimden 1.
    • Power off your GoPro before beginning disassembly.
    • Unclip the black latch to the camera case and open the case.
  2. GoPro Hero Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently pry the back open by inserting a metal spudger between the case and back panel.
  3. GoPro Hero Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery from the motherboard by unplugging the red, white, and black wires from the white adapter.
  4. GoPro Hero Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cable from the lens by lifting the black latch and gently pulling the ribbon cable from the socket.
  5. GoPro Hero Motherboard Replacement: adım 5, 1 resimden 1.
    • Use a Phillips screwdriver (PH000) to remove the four screws around the white plastic piece.
    • Make sure to keep track of these screws as they are very small.
  6. GoPro Hero Motherboard Replacement: adım 6, 1 resimden 1.
    • Carefully remove the motherboard and white plastic piece from the case.
  7. GoPro Hero Motherboard Replacement, Motherboard: adım 7, 2 resimden 1. GoPro Hero Motherboard Replacement, Motherboard: adım 7, 2 resimden 2.
    • Remove the larger ribbon cable from the daughter board by lifting the black latch and pulling the ribbon cable gently from the socket.
    • Disconnect the smaller ribbon cable leading from the white plastic piece by simply pulling it from the socket.
  8. GoPro Hero Motherboard Replacement: adım 8, 2 resimden 1. GoPro Hero Motherboard Replacement: adım 8, 2 resimden 2.
    • Separate the white plastic piece from the motherboard.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Zoe Tuggle
179 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Lancaster Spring 2015 Cal Poly, Team 12-2, Lancaster Spring 2015 üyesi
CPSU-LANCASTER-S15S12G2
4 Üyeler
18 adet Kılavuz yazıldı
2 Yorum
So after doing all theses steps did it resolve the problem
Anita - Yanıt
Thanks so much I really needed this guide.
Thanks, Sam
Sam Liam Matthews - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 24
Son 30 gün: 76
Her zaman: 10,747
