Ana içeriğe geç
Google Home Mini Disassembly
Neye ihtiyacın var
  1. Google Home Mini Disassembly, Google Home Mini Disassembly: adım 1, 1 resimden 1.
    • Place device on a flat surface.
  2. Google Home Mini Disassembly: adım 2, 1 resimden 1.
  3. Google Home Mini Disassembly: adım 3, 1 resimden 1.
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
    Black ribbon cable broken. Is there any chance to fix it. Please help. Thank you
    Deva Raj - Yanıt
  4. Google Home Mini Disassembly: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
    What if this breaks off. Can i direct connect power.
    Hlynur Jonasson - Yanıt
    Where to buy it please tell please
    Babu Vlogs - Yanıt
  5. Google Home Mini Disassembly: adım 5, 1 resimden 1.
    • Pull the ribbon cable off.
Sonuç
14 farklı kişi bu kılavuzu tamamladı.
Mia Sulaiman
1.080 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G4
7 Üyeler
5 adet Kılavuz yazıldı
2Kılavuz Yorumları
How did you get the rubber base off of it?
JAMES FLECKENSTEIN - Yanıt
There’s a little more explanation here
Google Home Mini Teardown
Ibby Dada -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 13
Son 30 gün: 55
Her zaman: 7,703
