Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace the primary loudspeaker in your Pixel 2 XL.
Neye ihtiyacın var
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
Press firmly to eject the tray.
Adım 3 Opening Procedure
Dikkatli ol: adımlar 3-14 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Use the flat end of a spudger to disconnect the battery connector.
Use the point of a spudger to disconnect the front-facing camera connector.
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
Remove the motherboard.
Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
7 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Does this method work with the earpiece one as well?
We don’t have official instructions out for the earpiece speaker, but it’s only accessible underneath the glass panel and antenna assembly on the back of the phone so removing it is a bit different. After removing the motherboard you would have to lift this flex cable from the back of the phone, just enough to separate it from the adhesive holding it down. Then you can carefully pry up the glass panel, and remove antenna assembly and the earpiece speaker underneath. You’ll probably need an iOpener, suction cup, and opening picks to remove the panel and everything underneath—they’re all glued down pretty solidly.
