Ana içeriğe geç
Google Pixel 2 XL Screen Replacement
Neye ihtiyacın var
    1. Google Pixel 2 XL Screen Replacement, Opening Procedure: adım 1, 2 resimden 1. Google Pixel 2 XL Screen Replacement, Opening Procedure: adım 1, 2 resimden 2.
      • If your display glass is cracked, tape over the glass to prevent bodily harm and further breakage. This also makes a smooth surface allowing the suction cup to bond.
      • Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
      • The suction cup will not make a good seal on the curved portion of the glass.
      FixBot'a Sor
      Yorum Ekle
    2. Google Pixel 2 XL Screen Replacement: adım 2, 3 resimden 1. Google Pixel 2 XL Screen Replacement: adım 2, 3 resimden 2. Google Pixel 2 XL Screen Replacement: adım 2, 3 resimden 3.
      • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
      • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
      FixBot'a Sor
      Yorum Ekle
    3. Google Pixel 2 XL Screen Replacement: adım 3, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 3, 2 resimden 2.
      • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
      • Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
      • Do not cut along the left edge; there are delicate display cables that can be damaged.
      • Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
      FixBot'a Sor
      Yorum Ekle
    4. Google Pixel 2 XL Screen Replacement: adım 4, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 4, 2 resimden 2.
      • Slide the opening pick down the right side of the phone to separate the display adhesive.
      FixBot'a Sor
      Yorum Ekle
    5. Google Pixel 2 XL Screen Replacement: adım 5, 3 resimden 1. Google Pixel 2 XL Screen Replacement: adım 5, 3 resimden 2. Google Pixel 2 XL Screen Replacement: adım 5, 3 resimden 3.
      • In the following steps, use the flat edge of the opening pick, rather than a corner, to cut. This will help prevent inserting the pick too deeply.
      • Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. Google Pixel 2 XL Screen Replacement: adım 6, 3 resimden 1. Google Pixel 2 XL Screen Replacement: adım 6, 3 resimden 2. Google Pixel 2 XL Screen Replacement: adım 6, 3 resimden 3.
      • Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
      FixBot'a Sor
      Yorum Ekle
    7. Google Pixel 2 XL Screen Replacement: adım 7, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 7, 2 resimden 2.
      • Gently lift the display from the right side of the phone, opening it like a book.
      • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive.
      • Don't try to fully separate the display yet, as fragile ribbon cables still connect it to the phone's motherboard.
      • Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
      FixBot'a Sor
      Yorum Ekle
    8. Google Pixel 2 XL Screen Replacement: adım 8, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 8, 2 resimden 2.
      • Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
      • The clip securing this cover is along the bottom edge.
      • Pry carefully to avoid damaging the cable underneath, or losing the cover itself.
      • Remove the connector cover.
      • Make sure to keep this component so you can reinstall it during reassembly.
      FixBot'a Sor
      Yorum Ekle
    9. Google Pixel 2 XL Screen Replacement: adım 9, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 9, 2 resimden 2.
      • Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      • If any part of your screen doesn't respond to touch after your repair, re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
      FixBot'a Sor
      Yorum Ekle
    10. Google Pixel 2 XL Screen Replacement: adım 10, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use tweezers to remove any tape from the display connector cover.
      FixBot'a Sor
      Yorum Ekle
    11. Google Pixel 2 XL Screen Replacement: adım 11, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 11, 2 resimden 2.
      • Insert the point of a spudger into the small hole on the edge of the display connector cover.
      • Use the spudger to pry the cover out of its recess.
      FixBot'a Sor
      Yorum Ekle
    12. Google Pixel 2 XL Screen Replacement: adım 12, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 12, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    1. Google Pixel 2 XL Screen Replacement, Screen: adım 13, 3 resimden 1. Google Pixel 2 XL Screen Replacement, Screen: adım 13, 3 resimden 2. Google Pixel 2 XL Screen Replacement, Screen: adım 13, 3 resimden 3.
      • Your replacement display may not come with pre-installed speaker grilles or a front-facing camera gasket. If that is the case, use tweezers to carefully remove these parts from your old display and follow the rest of the guide to install them on a new display.
      • Clean any adhesive residue off of the parts before reinstalling them.
      • Make sure to install the grilles and gasket before applying display adhesive.
      • Cut a strip of 1 mm wide double-sided tape to be about 3 cm (1.25 inches) long.
      • Lay the adhesive strip along the upper edge of the earpiece speaker slot in your new display so that it's centered over the slot and touching the upper edge.
      • The adhesive strip needs to be as close as possible to the edge of the slot without overlapping. Otherwise, it can interfere with the display adhesive.
      • Gently press the adhesive strip into place on the display with your finger or a spudger.
      • Peel the white backing away from the adhesive strip.
      FixBot'a Sor
      Yorum Ekle
    2. Google Pixel 2 XL Screen Replacement: adım 14, 3 resimden 1. Google Pixel 2 XL Screen Replacement: adım 14, 3 resimden 2. Google Pixel 2 XL Screen Replacement: adım 14, 3 resimden 3.
      • Lightly set the speaker grille into its slot so that the indented half of the grille sits inside the slot, and the flat, unindented half of the grille is above the slot on top of the adhesive. Do not push it onto the adhesive yet.
      • Use the point of a spudger to gently push the edges of the grille against the edges of the slot, centering the grille in the slot.
      FixBot'a Sor
      Yorum Ekle
    3. Google Pixel 2 XL Screen Replacement: adım 15, 2 resimden 1. Google Pixel 2 XL Screen Replacement: adım 15, 2 resimden 2.
      • Use the flat end of a spudger to push the top of the grille down against the adhesive strip.
      • Repeat the last three steps to install the lower speaker grille.
      • When installing the lower speaker grille, apply the adhesive strip to the lower edge of the speaker slot, and position the grille with the flat half below the slot.
      FixBot'a Sor
      Yorum Ekle
    4. Google Pixel 2 XL Screen Replacement: adım 16, 3 resimden 1. Google Pixel 2 XL Screen Replacement: adım 16, 3 resimden 2. Google Pixel 2 XL Screen Replacement: adım 16, 3 resimden 3.
      • If you're reusing the camera gasket from your old screen, the old adhesive may have stuck to the gasket when you removed it. If this is the case, and the adhesive is still sticky, skip to the last step.
      • Cut one strip of 1 mm wide adhesive to be 6 mm (1/4") long.
      • Place the adhesive underneath the front-facing camera hole, parallel to the top edge of the display.
      • Cut two 3 mm (1/8") strips of 1 mm wide adhesive.
      • Place the adhesive strips to the left and right of the camera hole, perpendicular to the bottom adhesive strip.
      • Gently press the adhesive strips into place on the display with your finger or a spudger.
      • Make sure all three strips are as close as possible to the camera hole, without overlapping the hole.
      FixBot'a Sor
      Yorum Ekle
    5. Google Pixel 2 XL Screen Replacement: adım 17, 1 resimden 1.
      • Peel the white backing off of all three adhesive strips.
      FixBot'a Sor
      Yorum Ekle
    6. Google Pixel 2 XL Screen Replacement: adım 18, 1 resimden 1.
      • Carefully place the front-facing camera gasket down on top of the adhesive.
      • Make sure that the gasket is centered around the camera hole. If it overlaps the hole at all, it will disrupt the function of the camera.
      • Press the gasket down against the adhesive with your finger or a spudger.
      • During the boot-up process after reassembly, the screen will go through a calibration sequence. Do not touch the screen during this process, as it could result in improper touch calibration and create touch issues.
      FixBot'a Sor
      Yorum Ekle
Sonuç
85 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
224.623 İtibar
416 adet Kılavuz yazıldı
43Kılavuz Yorumları
Be very careful on the bottom connection, if done incorrectly, 2 small components controlling bottom speaker are easily damaged, this will result in a motherboard replacement or replacing someones phone. Take it from me and a few others on the site…go at this slow and careful. Besides that risk, the phone is pretty simple to repair.
Tom Gray - Yanıt Paylaş
Hi Tom, what component are you talking about? I'm about to dive into this and it might be wise for me to doublecheck this prior to repairing it!
Jasperstaal - Yanıt Paylaş
can you separate outer glass screen layer from lcd?
Tyler W - Yanıt Paylaş
.Every layer of the full lamination screen is essential to the display, the surface layer is not just for protection.So I think if you removed it, the screen would be damaged .
roanoke - Yanıt Paylaş
Showing where to place the new tape would be helpful.
Office Administrator - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 18
Son 30 gün: 110
Her zaman: 140,638
