Giriş
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to remove and replace the front-facing selfie cameras for the Pixel 3. The cameras are modular and can be individually replaced.
When looking at the display, the wide-angle camera is on the left, while the normal angle camera is on the right.
This guide is also part of the motherboard removal guide and contains references related to motherboard removal.
Neye ihtiyacın var
Heat an iOpener and apply it to the bottom of the phone for one minute.
Apply a suction cup to the heated bottom edge of the back cover.
Lift on the suction cup with strong, steady force to create a gap.
Insert an opening pick into the gap.
Slice the adhesive along the bottom edge of the phone and around the right corner.
Leave a pick in the bottom edge to prevent the adhesive from re-sealing.
Once you have sliced around the perimeter of the phone, carefully lift the left edge of the back cover.
Flip the back cover along its long axis and rest it so that the fingerprint sensor cable is not strained.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove the two 4.1 mm-long Phillips screws securing the fingerprint connector bracket.
Use the point of a spudger to slide the fingerprint connector bracket out from under the NFC coil.
Remove the fingerprint connector bracket.
Use the point of a spudger to pry up and disconnect the fingerprint connector from its socket.
Remove the five Phillips screws securing the wireless charging coil:
Two 1.9 mm screws
Two 4.2 mm screws
One 4.3 mm screw
Use the point of a spudger to pry up and disconnect the battery press connector from its socket near the right edge of the phone.
Remove the two screws securing the camera bracket:
One 4.1 mm Phillips screw
One 4 mm standoff screw
Remove the camera bracket.
Use the point of a spudger to pry up and disconnect the connector for the camera(s) you are replacing.
Insert the point of a spudger behind the edge of the camera module and pry up to loosen it from the frame.
Bu adımda kullanılan alet:Tesa 61395 Tape$5.99
Use a pair of blunt nose tweezers to remove the camera(s).
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
Bir başkası bu kılavuzu tamamladı.
2Kılavuz Yorumları
There is only 1 front facing camera on a Pixel 3
Pixel 3 have two front facing cameras but Pixel 3a has only one.
