Ana içeriğe geç
Google Pixel 5 Screen Adhesive Installation
Neye ihtiyacın var
  1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Peel off as much adhesive as you can with a pair of tweezers.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    FixBot'a Sor
    Yorum Ekle
  2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: adım 2, 3 resimden 1. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: adım 2, 3 resimden 2. Google Pixel 5 Screen Adhesive Installation, Remove adhesive residue from the screen: adım 2, 3 resimden 3.
    • Repeat the previous step for the screen adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the screen.
    • Don't use isopropyl alcohol near the front camera bracket as it will loosen its adhesive.
    FixBot'a Sor
    Yorum Ekle
  3. Google Pixel 5 Screen Adhesive Installation, Align the adhesive: adım 3, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Align the adhesive: adım 3, 2 resimden 2.
    • Use the holes in the top right and bottom left corners of the frame to correctly align the adhesive:
    • The top right hole is circular
    • The bottom left hole is oblong
    FixBot'a Sor
    Yorum Ekle
  4. Google Pixel 5 Screen Adhesive Installation, Prepare the adhesive: adım 4, 1 resimden 1.
    • Peel away the clear plastic lining to expose the frame side of the adhesive.
    FixBot'a Sor
    Yorum Ekle
  5. Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: adım 5, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Apply the adhesive: adım 5, 2 resimden 2.
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the top right and bottom left corners to properly align the adhesive during installation.
    FixBot'a Sor
    Yorum Ekle
  6. Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: adım 6, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Secure the adhesive to the frame: adım 6, 2 resimden 2.
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    FixBot'a Sor
    Yorum Ekle
  7. Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: adım 7, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Peel away the outer plastic lining: adım 7, 2 resimden 2.
    • Use your fingers to grasp the blue plastic lining near the center and peel it away from the phone.
    • This should leave a thin perimeter of adhesive still covered by blue plastic lining.
    FixBot'a Sor
    Yorum Ekle
  8. Google Pixel 5 Screen Adhesive Installation, Connect the screen: adım 8, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Connect the screen: adım 8, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  9. Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: adım 9, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Peel away the remaining plastic lining: adım 9, 2 resimden 2.
    • Peel away the blue plastic lining to expose the perimeter adhesive.
    FixBot'a Sor
    Yorum Ekle
  10. Google Pixel 5 Screen Adhesive Installation, Position the screen: adım 10, 3 resimden 1. Google Pixel 5 Screen Adhesive Installation, Position the screen: adım 10, 3 resimden 2. Google Pixel 5 Screen Adhesive Installation, Position the screen: adım 10, 3 resimden 3.
    • Position the screen so it lays on the frame.
    FixBot'a Sor
    Yorum Ekle
  11. Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: adım 11, 2 resimden 1. Google Pixel 5 Screen Adhesive Installation, Press down the screen corners: adım 11, 2 resimden 2.
    • Press down the corners of the screen to secure them to the frame.
    FixBot'a Sor
    Yorum Ekle
  12. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: adım 12, 3 resimden 1. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: adım 12, 3 resimden 2. Google Pixel 5 Screen Adhesive Installation, Secure the screen to the frame: adım 12, 3 resimden 3.
    • Press down on the edges of the screen.
    • Slide along the perimeter to secure it to the frame.
    • You can heat the perimeter of the screen to soften the adhesive and help it bond more securely.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 5 Answers community for help.
34 farklı kişi bu kılavuzu tamamladı.
Chayton Ritter
27.002 İtibar
105 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
10 Üyeler
19.461 adet Kılavuz yazıldı
1Rehber Yorum
Vielen Dank für die ausführliche und hilfreiche Anleitung. Hat alles geklappt. Leider hatte ich die Schutzfolie über der Frontkamera übersehen. Die funktioniert jetzt nicht mehr. Das sollte noch in der Anleitung ergänzt werden.
Simon - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 40
Son 30 gün: 203
Her zaman: 13,596
