Giriş
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace the wireless charging assembly in your Google Pixel 9 Pro.
If your phone's wireless charging is intermittent or not charging at all, it may be time to replace the wireless charging assembly.
You'll need replacement rear cover adhesive to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the rear cover adhesive.
Neye ihtiyacın var
Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
Insert the tip of an opening pick in the gap.
Slide your opening along the bottom edge to separate the adhesive securing it.
Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
Bu adımda kullanılan alet:FixMat$36.95
Use a Torx Plus 3IP screwdriver to remove the five screws securing the wireless charging assembly:
Four 5.4 mm‑long screws
One 1.5 mm‑long screw
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
