Ana içeriğe geç
Google Pixel 9 Pro XL Wireless Charging Assembly Replacement
Neye ihtiyacın var
  1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Safety precautions: adım 1, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Safety precautions: adım 1, 2 resimden 2.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
  2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: adım 2, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: adım 2, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Adhesive information: adım 2, 3 resimden 3.
    • Adhesive secures the perimeter of the rear cover to the frame.
    • When separating the adhesive, don't insert your tool more than 3 mm under the rear cover to avoid damaging the internal components.
    • Measure 3 mm from the tip and mark your opening pick with a permanent marker. Alternatively, you can tape a coin to a pick 3 mm from the tip.
  3. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Apply a suction handle: adım 3, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Apply a suction handle: adım 3, 2 resimden 2.
    • Attach a suction handle to the bottom edge of the rear cover, as close to the edge as possible.
  4. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: adım 4, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: adım 4, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Pull up on the suction handle with strong, steady force to create a small gap under the rear cover.
    • Insert the tip of an opening pick in the gap.
  5. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: adım 5, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: adım 5, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Separate the rear cover adhesive: adım 5, 3 resimden 3.
    • Slide your opening along the bottom edge to separate the adhesive securing it.
    • Remember: don't insert the opening pick deeper than 3 mm.
  6. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 6, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 6, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 6, 3 resimden 3.
    • Slide your opening pick up the left edge and along the top edge to separate the adhesive.
  7. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 7, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 7, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 7, 3 resimden 3.
    • Slide your pick down the right edge to separate the remaining adhesive.
  8. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: adım 8, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: adım 8, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Prop up the rear cover: adım 8, 3 resimden 3.
    • Don't try to fully remove the rear cover yet, as a ribbon cable on the right edge connects it to the phone.
    • Use the suction handle to lift the left edge of the rear cover and swing it over the right edge, like opening the cover of a book.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • Prop up the rear cover with the suction handle so you can access the ribbon cable near the top right corner.
  9. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: adım 9, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: adım 9, 2 resimden 2.
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the cable cover.
  10. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 10, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 10, 2 resimden 2.
    • Use tweezers or your fingers to remove the cable cover.
  11. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: adım 11, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: adım 11, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the rear cover: adım 11, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the rear cover press connector.
  12. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the rear cover: adım 12, 1 resimden 1.
    • Remove the rear cover.
    • During reassembly, follow this guide to apply new adhesive and install your back cover.
  13. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: adım 13, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: adım 13, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Peel up the cable cover tape: adım 13, 3 resimden 3.
    • Use the tip of a spudger and your fingers to peel up the piece of tape near the left edge of your phone, enough that you can access the bracket and screws underneath.
    • You can completely remove the tape if you want, but be sure to keep it for reassembly.
  14. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: adım 14, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the cable cover: adım 14, 2 resimden 2.
    • Use a Torx Plus 3IP screwdriver to remove the two 5.2 mm‑long screws securing the wireless charging cable cover.
  15. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 15, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 15, 2 resimden 2.
    • Use tweezers or your fingers to remove the cover.
  16. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the wireless charging assembly: adım 16, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Disconnect the wireless charging assembly: adım 16, 2 resimden 2.
    • Use the tip of an opening pick to pry up and disconnect the wireless charging press‑connector.
  17. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 17, 3 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 17, 3 resimden 2. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement: adım 17, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the ultra‑wideband press connector.
  18. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: adım 18, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly screws: adım 18, 2 resimden 2.
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screw securing the wireless charging assembly.
  19. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly: adım 19, 2 resimden 1. Google Pixel 9 Pro XL Wireless Charging Assembly Replacement, Remove the wireless charging assembly: adım 19, 2 resimden 2.
    • Remove the wireless charging assembly.
Sonuç
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Spencer Day
96.225 İtibar
662 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 54
Her zaman: 385
