Ana içeriğe geç
Google Pixel Fold Earpiece Speaker Replacement
Neye ihtiyacın var
  1. Google Pixel Fold Earpiece Speaker Replacement, Safety Precautions: adım 1, 1 resimden 1.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel Fold Earpiece Speaker Replacement, Heat the bottom edge: adım 2, 1 resimden 1.
    • Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
  3. Google Pixel Fold Earpiece Speaker Replacement, Adhesive information: adım 3, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Adhesive information: adım 3, 2 resimden 2.
    • While you're waiting for the adhesive to soften, note the following:
    • The adhesive is under the dark black border surrounding the screen.
    • During the screen removal procedure, you only need to insert your opening pick as deep as the border.
    • Don't insert your pick any deeper, as you risk damaging the screen and internal components.
  4. Google Pixel Fold Earpiece Speaker Replacement, Insert an opening pick: adım 4, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Insert an opening pick: adım 4, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Insert an opening pick: adım 4, 3 resimden 3.
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  5. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom adhesive: adım 5, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom adhesive: adım 5, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom adhesive: adım 5, 3 resimden 3.
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom right corner before continuing.
  6. Google Pixel Fold Earpiece Speaker Replacement, Heat the right edge: adım 6, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  7. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom right adhesive: adım 7, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom right adhesive: adım 7, 2 resimden 2.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  8. Google Pixel Fold Earpiece Speaker Replacement, Separate the right adhesive: adım 8, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the right adhesive: adım 8, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Separate the right adhesive: adım 8, 3 resimden 3.
    • Insert a new opening pick in the bottom right corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
    • Leave the opening pick in the top right corner before continuing.
  9. Google Pixel Fold Earpiece Speaker Replacement, Heat the top edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  10. Google Pixel Fold Earpiece Speaker Replacement, Separate the top right adhesive: adım 10, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the top right adhesive: adım 10, 2 resimden 2.
    • Rotate the opening pick around the top right corner to separate its adhesive.
  11. Google Pixel Fold Earpiece Speaker Replacement, Separate the top adhesive: adım 11, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the top adhesive: adım 11, 2 resimden 2.
    • Insert a new opening pick in the top right corner.
    • Slide the opening pick toward the top left corner to separate its adhesive.
  12. Google Pixel Fold Earpiece Speaker Replacement, Heat the left edge: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  13. Google Pixel Fold Earpiece Speaker Replacement, Separate the top left adhesive: adım 13, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the top left adhesive: adım 13, 2 resimden 2.
    • The sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the screen.
    • Rotate the opening pick around the top left corner to separate the adhesive.
  14. Google Pixel Fold Earpiece Speaker Replacement, Separate the left adhesive: adım 14, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the left adhesive: adım 14, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Separate the left adhesive: adım 14, 3 resimden 3.
    • Insert a new opening pick in the top left corner.
    • Slide the opening pick toward the bottom left corner to separate the adhesive.
  15. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom left adhesive: adım 15, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the bottom left adhesive: adım 15, 2 resimden 2.
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  16. Google Pixel Fold Earpiece Speaker Replacement, Adhesive information: adım 16, 1 resimden 1.
    • There's a small adhesive strip that secures the screen near the top right corner of the phone.
    • The next three steps will show you how to separate this adhesive.
  17. Google Pixel Fold Earpiece Speaker Replacement, Heat the top right corner: adım 17, 1 resimden 1.
    • Heat an iOpener and apply it to the top right corner of the screen for two minutes.
  18. Google Pixel Fold Earpiece Speaker Replacement, Insert an opening pick: adım 18, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Insert an opening pick: adım 18, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Insert an opening pick: adım 18, 3 resimden 3.
    • Insert an opening pick under the right edge of the screen, near the top right corner.
    • Push the opening pick under the screen as far you can go without losing your grip.
  19. Google Pixel Fold Earpiece Speaker Replacement, Separate the adhesive: adım 19, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the adhesive: adım 19, 2 resimden 2.
    • Be very careful during this step, as you risk breaking the screen. Work slowly and apply more heat if necessary.
    • Twist the opening pick back and forth to separate the adhesive.
    • If you don't feel the adhesive separating, apply more heat or insert the pick at a different angle.
  20. Google Pixel Fold Earpiece Speaker Replacement, Reposition the screen: adım 20, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Reposition the screen: adım 20, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Reposition the screen: adım 20, 3 resimden 3.
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Don't remove the screen yet, as it's still connected to the phone by a cable.
    • Swing the left edge of the screen up and over the right edge of the phone.
    • Let the screen rest next to the phone before continuing.
  21. Google Pixel Fold Earpiece Speaker Replacement, Unfasten the bottom bracket: adım 21, 1 resimden 1.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    Satın Al
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 Torx or T4 bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
  22. Google Pixel Fold Earpiece Speaker Replacement, Remove the bottom bracket: adım 22, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Remove the bottom bracket: adım 22, 2 resimden 2.
    Satın Al
    • Use tweezers, or your fingers, to remove the bottom bracket.
    • During reassembly, make sure the bottom bracket is sitting in its two alignment pegs before refastening it.
  23. Google Pixel Fold Earpiece Speaker Replacement, Disconnect the flip battery: adım 23, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Disconnect the flip battery: adım 23, 2 resimden 2.
    • Don't pry against the battery during this step. Angle your spudger under the left or right edges of the press connector.
    • Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  24. Google Pixel Fold Earpiece Speaker Replacement, Disconnect the screen: adım 24, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Disconnect the screen: adım 24, 2 resimden 2.
    • Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
    • Don't insert your spudger anywhere else, as you risk damaging surface-mounted components on the logic board.
    • Pry up to disconnect the screen press connector.
  25. Google Pixel Fold Earpiece Speaker Replacement, Remove the screen: adım 25, 1 resimden 1.
    • Remove the screen.
  26. Google Pixel Fold Earpiece Speaker Replacement, Reassembly information: adım 26, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Reassembly information: adım 26, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Reassembly information: adım 26, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    Satın Al
    • During reassembly, perform the following:
    • If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
    • Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
    • If your top right adhesive is still intact and sticky, you can reuse it.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace your screen adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the screen to the frame.
  27. Google Pixel Fold Earpiece Speaker Replacement, Unfasten the top bracket: adım 27, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Unfasten the top bracket: adım 27, 2 resimden 2.
    Satın Al
    • Use a Torx Plus 3IP screwdriver to remove the three 2.5 mm‑long screws securing the top bracket.
    • There's a magnet at the top right corner of phone. As you remove nearby screws, they might stick the magnet.
    • If you're having trouble inserting these screws, use tweezers to hold it in place while you screw in the first few threads.
  28. Google Pixel Fold Earpiece Speaker Replacement, Remove the top bracket: adım 28, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Remove the top bracket: adım 28, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Remove the top bracket: adım 28, 3 resimden 3.
    • The flip vibrator is attached to the underside of the top bracket.
    • Pull the top bracket toward the left edge of the phone to separate it from its recess in the frame.
    • Remove the top bracket.
    • During reassembly, insert the right edge of the top bracket under its lip in the frame before aligning the screw holes.
  29. Google Pixel Fold Earpiece Speaker Replacement, Remove the top speaker: adım 29, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Remove the top speaker: adım 29, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Remove the top speaker: adım 29, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    Satın Al
    • Don't pry against the battery with the spudger, as you risk damaging it.
    • The top speaker is lightly adhered to the frame.
    • Insert the flat end of a spudger between the battery and the bottom edge of the top speaker.
    • Twist the spudger to separate the adhesive securing the bottom speaker.
    • Remove the top speaker.
    • During reassembly, if your adhesive is still intact and sticky, you can reuse it. Otherwise, follow this guide to replace the adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the speaker to the frame.
  30. Google Pixel Fold Earpiece Speaker Replacement, Disconnect the top interconnect cable: adım 30, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Disconnect the top interconnect cable: adım 30, 2 resimden 2.
    • Use the flat end of spudger to pry up and disconnect the top interconnect cable press connector.
  31. Google Pixel Fold Earpiece Speaker Replacement, Remove the upper board: adım 31, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Remove the upper board: adım 31, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Remove the upper board: adım 31, 3 resimden 3.
    • Pull the upper board toward the bottom of the phone to separate it from its recess in the frame
    • Remove the upper board.
    • During reassembly, make sure the upper board sits in its alignment peg before securing anything to it.
  32. Google Pixel Fold Earpiece Speaker Replacement, Remove the detune board: adım 32, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Remove the detune board: adım 32, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Remove the detune board: adım 32, 3 resimden 3.
    • Insert the flat end of a spudger under the bottom of the detune board.
    • Twist the spudger to separate the board from its metal clip.
    • Remove the detune board.
  33. Google Pixel Fold Earpiece Speaker Replacement, Reassembly information: adım 33, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Reassembly information: adım 33, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Reassembly information: adım 33, 3 resimden 3.
    • During reassembly, perform the following to secure the detune board:
    • Angle the detune board downward against the right edge of the frame.
    • Press the board against the right edge of the frame to engage its spring connector.
    • Press downward to slot the board into its clip and secure it to the frame.
  34. Google Pixel Fold Earpiece Speaker Replacement, Heat the earpiece speaker: adım 34, 1 resimden 1.
    • Heat an iOpener and apply it to the earpiece speaker for two minutes.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the displays and/or internal batteries, so proceed with care.
  35. Google Pixel Fold Earpiece Speaker Replacement, Separate the adhesive: adım 35, 2 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Separate the adhesive: adım 35, 2 resimden 2.
    • Insert the flat end of a spudger between the frame and the bottom of the earpiece speaker.
    • Twist the spudger to separate the adhesive under the body of the earpiece speaker.
    • If you're having trouble separating the adhesive, you can also use an opening pick to slide under the speaker.
  36. Google Pixel Fold Earpiece Speaker Replacement, Remove the earpiece speaker: adım 36, 3 resimden 1. Google Pixel Fold Earpiece Speaker Replacement, Remove the earpiece speaker: adım 36, 3 resimden 2. Google Pixel Fold Earpiece Speaker Replacement, Remove the earpiece speaker: adım 36, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    Satın Al
    • The earpiece speaker connector is mildly adhered to the frame.
    • Grab the right edge of the earpiece speaker and pull it away from the frame to separate the connector adhesive.
    • If you're feeling a lot of resistance, apply heat and try again.
    • Remove the earpiece speaker.
    • During reassembly, if your adhesive is still intact and sticky, you can reuse it. Otherwise, follow this guide to replace the adhesive with custom cut strips.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
129.318 İtibar
600 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.077 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 144
