Ana içeriğe geç
Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq)
Alex Diaz-Kokaisl
Alex Diaz-Kokaisl ve başka bir katkıda bulunan
En son May 7, 2024 tarihinde güncellendi
30 - 45 dakika
Orta
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Use this guide to replace the outer screen in your Google Pixel Fold.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Safety Precautions: adım 1, 1 resimden 1.
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Heat the bottom edge: adım 2, 1 resimden 1.
    • Flip over your phone so the outer screen is facing up.
    • Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
  3. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Adhesive information: adım 3, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Adhesive information: adım 3, 2 resimden 2.
    • While you're waiting for the adhesive to soften, note the following:
    • The adhesive is under the dark black border surrounding the screen.
    • During this screen removal procedure, you only need to insert your opening pick as deep as the border.
    • Don't insert your pick any deeper, as you risk damaging the screen and internal components.
  4. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Insert an opening pick: adım 4, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Insert an opening pick: adım 4, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Insert an opening pick: adım 4, 3 resimden 3.
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your screen is badly cracked, cover it with a layer of clear packing tape to help the suction cup adhere. Alternatively, you can pull using very strong tape instead of a suction cup. If all else fails, try supergluing the suction cup to the broken screen.
  5. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom adhesive: adım 5, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom adhesive: adım 5, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom adhesive: adım 5, 3 resimden 3.
    • Slide the opening pick back and forth along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom right corner before continuing.
  6. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Heat the right edge: adım 6, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  7. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom right adhesive: adım 7, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom right adhesive: adım 7, 2 resimden 2.
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  8. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the right adhesive: adım 8, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the right adhesive: adım 8, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the right adhesive: adım 8, 3 resimden 3.
    • Insert a second opening pick in the bottom right corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
    • Leave the opening pick in the top right corner before continuing.
  9. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Heat the top edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  10. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the top right adhesive: adım 10, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the top right adhesive: adım 10, 2 resimden 2.
    • Rotate the opening pick around the top right corner to separate the adhesive.
  11. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the top adhesive: adım 11, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the top adhesive: adım 11, 2 resimden 2.
    • Insert a third opening pick in the top right corner.
    • Slide the opening pick toward the top left corner to separate the adhesive.
  12. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Heat the left edge: adım 12, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  13. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the top left adhesive: adım 13, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the top left adhesive: adım 13, 2 resimden 2.
    • This sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the screen.
    • Rotate the opening pick around the top left corner to separate the adhesive.
  14. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the left adhesive: adım 14, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the left adhesive: adım 14, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the left adhesive: adım 14, 3 resimden 3.
    • Insert a fourth opening pick in the top left corner.
    • Slide the opening pick toward the bottom left corner to separate the adhesive.
  15. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom left adhesive: adım 15, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the bottom left adhesive: adım 15, 2 resimden 2.
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  16. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Adhesive information: adım 16, 1 resimden 1.
    • Adhesive information:
    • There's a small adhesive strip that secures the screen near the top right corner of the phone.
    • The next three steps will show you how to separate this adhesive.
  17. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Heat the top right corner: adım 17, 1 resimden 1.
    • Heat an iOpener and apply it to the top right corner of the screen for two minutes.
  18. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Insert an opening pick: adım 18, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Insert an opening pick: adım 18, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Insert an opening pick: adım 18, 3 resimden 3.
    • Insert an opening pick under the right edge of the screen, near the top right corner.
    • Push the opening pick under the screen as far you can go without losing your grip.
  19. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the adhesive: adım 19, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Separate the adhesive: adım 19, 2 resimden 2.
    • Be very careful during this step, as you risk breaking the screen. Work slowly and apply more heat if necessary.
    • Twist or "wiggle" the opening pick back and forth to separate the adhesive.
    • If you don't feel the adhesive separating, apply more heat or insert the pick at a different angle.
  20. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Reposition the screen: adım 20, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Reposition the screen: adım 20, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Reposition the screen: adım 20, 3 resimden 3.
    • Don't remove the screen yet, as it's still connected to the phone by a cable.
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Swing the left edge of the screen up and over the right edge of the phone.
    • Let the screen rest next to the phone before continuing.
  21. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Unfasten the bottom bracket: adım 21, 1 resimden 1.
    • Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
  22. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Remove the bottom bracket: adım 22, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Remove the bottom bracket: adım 22, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use tweezers, or your fingers, to remove the bottom bracket.
    • During reassembly, make sure the bottom bracket is sitting in its two alignment pegs before refastening it.
  23. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Disconnect the flip battery: adım 23, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Disconnect the flip battery: adım 23, 2 resimden 2.
    • Don't pry against the battery during this step. Angle your spudger under the left or right edges of the press connector.
    • Use the flat end of spudger to pry up and disconnect the flip battery press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  24. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Disconnect the screen: adım 24, 2 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Disconnect the screen: adım 24, 2 resimden 2.
    • Insert the point of a spudger under the bottom edge of the screen press connector.
    • Don't insert your spudger anywhere else, as you risk damaging surface-mounted components on the logic board.
    • Pry up to disconnect the screen press connector.
  25. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Remove the screen: adım 25, 1 resimden 1.
    • Remove the screen.
  26. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Reassembly information: adım 26, 3 resimden 1. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Reassembly information: adım 26, 3 resimden 2. Google Pixel Fold Outer Screen Replacement (Inner Screen Assembly Prereq), Reassembly information: adım 26, 3 resimden 3.
    Tesa 61395 Tape
    $5.99
    • During reassembly:
    • If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
    • Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
    • If your top right adhesive is still intact and sticky, you can reuse it.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace your screen adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the screen to the frame.
Sonuç
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
164.759 İtibar
769 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.776 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 37
