Ana içeriğe geç
GravityLight Internal Gears Replacement
Michallynn Hoffman
Michallynn Hoffman ve başka bir katkıda bulunan
En son January 12, 2015 tarihinde güncellendi
5 - 10 dakika
Orta
Öne Çıkan Öğrenci Kılavuzu
If the bag of rocks is not moving due to an internal issue, it might be because the gears are stripped! You will learn how to replace them.
Neye ihtiyacın var
Aletler
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: adım 1, 2 resimden 1. GravityLight Internal Gears Replacement, Removing the Front Panel: adım 1, 2 resimden 2.
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: adım 2, 1 resimden 1.
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: adım 3, 1 resimden 1.
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: adım 4, 1 resimden 1.
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: adım 5, 1 resimden 1.
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: adım 6, 1 resimden 1.
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: adım 7, 2 resimden 1. GravityLight Internal Gears Replacement, Removing Internal Gears: adım 7, 2 resimden 2.
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
Sonuç
Michallynn Hoffman
317 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G2
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Where can we find the replacement gears?
fb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 3,128
