Ana içeriğe geç
Grip Tape Application
Neye ihtiyacın var
  1. Grip Tape Application, Grip Tape Application: adım 1, 1 resimden 1.
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Grip Tape Application: adım 2, 1 resimden 1.
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Grip Tape Application: adım 3, 2 resimden 1. Grip Tape Application: adım 3, 2 resimden 2.
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Grip Tape Application: adım 4, 2 resimden 1. Grip Tape Application: adım 4, 2 resimden 2.
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Grip Tape Application: adım 5, 3 resimden 1. Grip Tape Application: adım 5, 3 resimden 2. Grip Tape Application: adım 5, 3 resimden 3.
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Grip Tape Application: adım 6, 1 resimden 1.
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. Grip Tape Application: adım 7, 1 resimden 1.
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. Grip Tape Application: adım 8, 2 resimden 1. Grip Tape Application: adım 8, 2 resimden 2.
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
Sonuç
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
4 farklı kişi bu kılavuzu tamamladı.
Jared Stine
800 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G32
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 19
Her zaman: 8,179
