Ana içeriğe geç
Skateboard Trucks Replacement
Neye ihtiyacın var
  1. Skateboard Trucks Replacement, Trucks: adım 1, 2 resimden 1. Skateboard Trucks Replacement, Trucks: adım 1, 2 resimden 2.
    • Insert bolt hardware through the factory drilled holes from the top side of the skateboard.
    • If you have a riser and would like to install it, please reference the Wheel Bite Prevention guide.
    FixBot'a Sor
    Yorum Ekle
  2. Skateboard Trucks Replacement: adım 2, 1 resimden 1.
    • Slide the truck onto the four protruding bolt hardware screws, while using your hand to prevent the screws from popping out the top of the skateboard.
    FixBot'a Sor
    Yorum Ekle
  3. Skateboard Trucks Replacement: adım 3, 1 resimden 1.
    • Hand tighten the nut hardware onto all four bolts.
    FixBot'a Sor
    Yorum Ekle
  4. Skateboard Trucks Replacement: adım 4, 1 resimden 1.
    • While holding the nuts on the bottom side of the skateboard in place with the 3/8" wrench, tighten the screws from the top side of the skateboard with a screwdriver. Tighten the screws in a diagonal pattern until the head of the screw sinks slightly into the grip tape.
    • Repeat steps 1 - 6 to install the second truck.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To uninstall your trucks, simply follow these steps in reverse order. To continue assembling your skateboard deck, see the Wheel Installation guide.
2 farklı kişi bu kılavuzu tamamladı.
Cameron Nye
79 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G32
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 39
Her zaman: 13,908
