Ana içeriğe geç
Guitar Hero World Tour Guitar Strummer Replacement
Daniel Koelzer
Daniel Koelzer ve 2 diğer katkıda bulunanlar
En son January 26, 2024 tarihinde güncellendi
15 - 30 dakika
Kolay
This guide will demonstrate how to clean or replace the strummer (strum bar) for a Guitar Hero: World Tour Controller.
The strummer can often become sluggish or stuck from wear and tear over time. This can often be solved by simply cleaning or lubricating the strum bar, or by replacing it entirely if damaged.
Two AA batteries will need to be removed as shown in the guide.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Guitar Hero World Tour Guitar Strummer Replacement, Strummer: adım 1, 3 resimden 1. Guitar Hero World Tour Guitar Strummer Replacement, Strummer: adım 1, 3 resimden 2. Guitar Hero World Tour Guitar Strummer Replacement, Strummer: adım 1, 3 resimden 3.
    • Remove the battery cover.
    • Remove the two AA batteries.
  2. Guitar Hero World Tour Guitar Strummer Replacement: adım 2, 3 resimden 1. Guitar Hero World Tour Guitar Strummer Replacement: adım 2, 3 resimden 2. Guitar Hero World Tour Guitar Strummer Replacement: adım 2, 3 resimden 3.
    • Move the switch from "Locked" to the "Unlocked" position.
    • Remove the neck from the body of the guitar.
    • This will likely take two hands.
  3. Guitar Hero World Tour Guitar Strummer Replacement: adım 3, 3 resimden 1. Guitar Hero World Tour Guitar Strummer Replacement: adım 3, 3 resimden 2. Guitar Hero World Tour Guitar Strummer Replacement: adım 3, 3 resimden 3.
    • Ensure the face-plate lock is in the "Unlocked" position.
    • Pry the face plate off of the body by gently prying with an opening tool near the marked locations. The face plate should not be difficult to remove.
    • You can pry the face plate away with your fingers, or with any plastic/wooden tool.
    • Avoid using metal tools to pry the plastic face plate away, as it can lead to marring the plastic and ruining the finish.
  4. Guitar Hero World Tour Guitar Strummer Replacement: adım 4, 3 resimden 1. Guitar Hero World Tour Guitar Strummer Replacement: adım 4, 3 resimden 2. Guitar Hero World Tour Guitar Strummer Replacement: adım 4, 3 resimden 3.
    • Remove the eleven Torx T10 screws.
    • Remove the four Phillips #0 screws.
    • There is an additional Torx T10 screw located behind the "Warranty Void" sticker.
    • Separate the two halves of the guitar body.
  5. Guitar Hero World Tour Guitar Strummer Replacement: adım 5, 3 resimden 1. Guitar Hero World Tour Guitar Strummer Replacement: adım 5, 3 resimden 2. Guitar Hero World Tour Guitar Strummer Replacement: adım 5, 3 resimden 3.
    • Disconnect the ribbon cable connecting the strummer circuit board to the main control board.
    • Remove the eight Phillips #0 screws holding the strummer circuit board to the body.
    • Ensure that the switches have a solid clicking action.
    • Debris can often block the switches from actuating.
  6. Guitar Hero World Tour Guitar Strummer Replacement: adım 6, 3 resimden 1. Guitar Hero World Tour Guitar Strummer Replacement: adım 6, 3 resimden 2. Guitar Hero World Tour Guitar Strummer Replacement: adım 6, 3 resimden 3.
    • Remove four Phillips #0 screws holding the strum bar assembly.
    • Remove the strum bar assembly from the body. Ensure that both springs are present and in good condition.
    • Check the joint between the strum bar and its mounting brackets. Ensure there are no foreign objects jamming the hole. Ensure the joint is well lubricated.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Great guide! Helped me find some loose screws that fixed the strumming when tightened.
Only note is that my controller uses Torx T6 screws instead of Phillips #0 screws. From info online, it looks like these controllers can have either type.
Nicholas Stecyna - Yanıt
Yes, The RedOctane (95457.805) edition has no Phillips #0 screws, but but T6 size screws so this may be an edition or region difference? This RedOctane wireless one is in EU region.
Kullitore -
How much difference is there between this and a guitar hero 5 guitar ? Having an issue when I strum up the strum bar sticks and doesn’t return to center not sure if it’s an issue with friction or the switches are bad
Bill Crampton - Yanıt
Hey can anyone help me was playing guitar hero world tour just fine but today my guitar will not strum up or down on the game but move just fine on my xbox 360 dashboard.i just don't get it
Benjamin Ward - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 54
Son 30 gün: 203
Her zaman: 15,679
