Ana içeriğe geç
HMD Fusion Screen Replacement
Neye ihtiyacın var
  1. HMD Fusion Screen Replacement, Prepare your phone for disassembly: adım 1, 1 resimden 1.
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone and completely power it down.
    FixBot'a Sor
    Yorum Ekle
  2. HMD Fusion Screen Replacement, Remove the SIM card tray: adım 2, 3 resimden 1. HMD Fusion Screen Replacement, Remove the SIM card tray: adım 2, 3 resimden 2. HMD Fusion Screen Replacement, Remove the SIM card tray: adım 2, 3 resimden 3.
    • Firmly press a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the left edge of your phone until the tray ejects.
    • Remove the SIM card tray.
    FixBot'a Sor
    Yorum Ekle
  3. HMD Fusion Screen Replacement, Remove the back cover screws: adım 3, 3 resimden 1. HMD Fusion Screen Replacement, Remove the back cover screws: adım 3, 3 resimden 2. HMD Fusion Screen Replacement, Remove the back cover screws: adım 3, 3 resimden 3.
    • Use a T3 Torx screwdriver to remove the sixteen 5.0 mm‑long screws securing the back cover.
    • Use your fingernails, or angled tweezers, to remove any stuck screws.
    • The screws are secured tightly in the back cover, so you might not be able to remove all of them. If you can't remove a few screws, don't worry! Move to the next step and follow the guide normally.
    FixBot'a Sor
    Yorum Ekle
  4. HMD Fusion Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • During the next four steps, the remaining back cover screws might fall out unexpectedly.
    • To avoid losing screws, you can place a tray, bowl, or Magnetic Project Mat under the phone while you work.
    FixBot'a Sor
    Yorum Ekle
  5. HMD Fusion Screen Replacement, Unclip the back cover: adım 5, 2 resimden 1. HMD Fusion Screen Replacement, Unclip the back cover: adım 5, 2 resimden 2.
    • Flip your phone over so the screen is facing up.
    • Insert the tip of an opening pick between the back cover and frame at the SIM card tray cutout.
    FixBot'a Sor
    Yorum Ekle
  6. HMD Fusion Screen Replacement: adım 6, 3 resimden 1. HMD Fusion Screen Replacement: adım 6, 3 resimden 2. HMD Fusion Screen Replacement: adım 6, 3 resimden 3.
    • Slide the opening pick along the left edge to begin unclipping the back cover.
    FixBot'a Sor
    Yorum Ekle
  7. HMD Fusion Screen Replacement: adım 7, 3 resimden 1. HMD Fusion Screen Replacement: adım 7, 3 resimden 2. HMD Fusion Screen Replacement: adım 7, 3 resimden 3.
    • Continue sliding the pick around the perimeter of your phone until the back cover is fully unclipped.
    • The corners can be tricky to unclip and may take some force. If you're having trouble, try prying up with the pick.
    • Don't try to fully remove the cover yet, as it's still connected by a delicate cable.
    FixBot'a Sor
    Yorum Ekle
  8. HMD Fusion Screen Replacement: adım 8, 3 resimden 1. HMD Fusion Screen Replacement: adım 8, 3 resimden 2. HMD Fusion Screen Replacement: adım 8, 3 resimden 3.
    • Carefully flip your phone over so the back cover is facing up.
    • Lift the back cover off the frame and flip it over the left edge of your phone, laying the cover flat on your work surface.
    • Be very careful not to strain the back cover's delicate cable.
    • During reassembly, place the back cover onto the frame and firmly press around the perimeter to reengage all the clips.
    FixBot'a Sor
    Yorum Ekle
  9. HMD Fusion Screen Replacement, Disconnect the battery: adım 9, 3 resimden 1. HMD Fusion Screen Replacement, Disconnect the battery: adım 9, 3 resimden 2. HMD Fusion Screen Replacement, Disconnect the battery: adım 9, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  10. HMD Fusion Screen Replacement, Disconnect the power button: adım 10, 3 resimden 1. HMD Fusion Screen Replacement, Disconnect the power button: adım 10, 3 resimden 2. HMD Fusion Screen Replacement, Disconnect the power button: adım 10, 3 resimden 3.
    • Use a spudger to pry up and disconnect the power button press connector.
    • Remove the back cover.
    FixBot'a Sor
    Yorum Ekle
  11. HMD Fusion Screen Replacement, Screen: adım 11, 3 resimden 1. HMD Fusion Screen Replacement, Screen: adım 11, 3 resimden 2. HMD Fusion Screen Replacement, Screen: adım 11, 3 resimden 3.
    • For the next step, you'll need to hold the graphite sheet out of the way of the display connector along the bottom of the motherboard.
    • Alternatively, you can use tape with light adhesive (such as painter's tape) to keep the graphite sheet out of the way.
    FixBot'a Sor
    Yorum Ekle
  12. HMD Fusion Screen Replacement, Disconnect the display: adım 12, 2 resimden 1. HMD Fusion Screen Replacement, Disconnect the display: adım 12, 2 resimden 2.
    • Use a spudger to pry up and disconnect the display press connector.
    • Pry under the right edge of the connector, as there are delicate surface‑mounted components to the left of it.
    FixBot'a Sor
    Yorum Ekle
  13. HMD Fusion Screen Replacement, Separate the front camera: adım 13, 2 resimden 1. HMD Fusion Screen Replacement, Separate the front camera: adım 13, 2 resimden 2.
    • Use the tip of a spudger to pry up the front camera from the frame and separate its adhesive.
    FixBot'a Sor
    Yorum Ekle
  14. HMD Fusion Screen Replacement, Remove the screen screws: adım 14, 2 resimden 1. HMD Fusion Screen Replacement, Remove the screen screws: adım 14, 2 resimden 2.
    • Use a T3 Torx screwdriver to remove the seven 3.3 mm‑long screws securing the screen:
    • Five screws on the motherboard
    • Two screws on the loudspeaker
    • One of the screws on the loudspeaker may be covered by a sticker. Pierce through it with your screwdriver, or use tweezers to remove it.
    FixBot'a Sor
    Yorum Ekle
  15. HMD Fusion Screen Replacement, Remove the screen: adım 15, 2 resimden 1. HMD Fusion Screen Replacement, Remove the screen: adım 15, 2 resimden 2.
    • Lift the screen off the frame, making sure to thread the display cable through its slot.
    • Remove the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Alex Diaz-Kokaisl
241.094 İtibar
1.180 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
122 Üyeler
26.593 adet Kılavuz yazıldı
6Kılavuz Yorumları
Wo kann ich ein Ersatzdisplay bestellen? (Bin aus der Schweiz)
Ivan Haedo - Yanıt Paylaş
Will the parts ever be in stock in Europe? Pointless to buy a repairable phone when you can't buy the parts
Ejrj - Yanıt Paylaş
In teh description you remove the screen, but Ifix send a sreen with a frame fixed to it. no way this is gona fit.
L Verheul - Yanıt Paylaş
Yes, the new screen has a frame attached to it. Just remove every screw on it an detach the frame carefully. I guess the frame supports the screen for transportation.
Robert Reiter - Yanıt Paylaş
Hello, I am in Portugal, can I buy the screen on this website?
Sand.barack - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 96
Son 30 gün: 376
Her zaman: 7,728
