Ana içeriğe geç
HMDX Chill Audio Port Replacement
Neye ihtiyacın var
  1. HMDX Chill Audio Port Replacement, Remove Rubber Base: adım 1, 3 resimden 1. HMDX Chill Audio Port Replacement, Remove Rubber Base: adım 1, 3 resimden 2. HMDX Chill Audio Port Replacement, Remove Rubber Base: adım 1, 3 resimden 3.
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
    FixBot'a Sor
    Yorum Ekle
  2. HMDX Chill Audio Port Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
    FixBot'a Sor
    Yorum Ekle
  3. HMDX Chill Audio Port Replacement: adım 3, 2 resimden 1. HMDX Chill Audio Port Replacement: adım 3, 2 resimden 2.
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
    FixBot'a Sor
    Yorum Ekle
  4. HMDX Chill Audio Port Replacement, Motherboard: adım 4, 3 resimden 1. HMDX Chill Audio Port Replacement, Motherboard: adım 4, 3 resimden 2. HMDX Chill Audio Port Replacement, Motherboard: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
    FixBot'a Sor
    Yorum Ekle
  5. HMDX Chill Audio Port Replacement: adım 5, 1 resimden 1.
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
    FixBot'a Sor
    Yorum Ekle
  6. HMDX Chill Audio Port Replacement: adım 6, 3 resimden 1. HMDX Chill Audio Port Replacement: adım 6, 3 resimden 2. HMDX Chill Audio Port Replacement: adım 6, 3 resimden 3.
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
    FixBot'a Sor
    Yorum Ekle
  7. HMDX Chill Audio Port Replacement: adım 7, 2 resimden 1. HMDX Chill Audio Port Replacement: adım 7, 2 resimden 2.
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
    FixBot'a Sor
    Yorum Ekle
  8. HMDX Chill Audio Port Replacement: adım 8, 1 resimden 1.
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
    FixBot'a Sor
    Yorum Ekle
  9. HMDX Chill Audio Port Replacement, Audio Jack: adım 9, 1 resimden 1.
    • Desolder the audio jack from the motherboard using a soldering iron.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jourdan Holubasch
759 İtibar
7 adet Kılavuz yazıldı
Ekip
EWU-Giguere-S16S1G1 EWU-Giguere-S16S1G1 üyesi
Community
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 611
