Ana içeriğe geç
HMDX Chill Charging Port Replacement
Neye ihtiyacın var
  1. HMDX Chill Charging Port Replacement, Remove Rubber Base: adım 1, 3 resimden 1. HMDX Chill Charging Port Replacement, Remove Rubber Base: adım 1, 3 resimden 2. HMDX Chill Charging Port Replacement, Remove Rubber Base: adım 1, 3 resimden 3.
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
    FixBot'a Sor
    Yorum Ekle
  2. HMDX Chill Charging Port Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
    FixBot'a Sor
    Yorum Ekle
  3. HMDX Chill Charging Port Replacement: adım 3, 2 resimden 1. HMDX Chill Charging Port Replacement: adım 3, 2 resimden 2.
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
    FixBot'a Sor
    Yorum Ekle
  4. HMDX Chill Charging Port Replacement, Motherboard: adım 4, 3 resimden 1. HMDX Chill Charging Port Replacement, Motherboard: adım 4, 3 resimden 2. HMDX Chill Charging Port Replacement, Motherboard: adım 4, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
    FixBot'a Sor
    Yorum Ekle
  5. HMDX Chill Charging Port Replacement: adım 5, 1 resimden 1.
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
    FixBot'a Sor
    Yorum Ekle
  6. HMDX Chill Charging Port Replacement: adım 6, 3 resimden 1. HMDX Chill Charging Port Replacement: adım 6, 3 resimden 2. HMDX Chill Charging Port Replacement: adım 6, 3 resimden 3.
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
    FixBot'a Sor
    Yorum Ekle
  7. HMDX Chill Charging Port Replacement: adım 7, 2 resimden 1. HMDX Chill Charging Port Replacement: adım 7, 2 resimden 2.
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
    FixBot'a Sor
    Yorum Ekle
  8. HMDX Chill Charging Port Replacement: adım 8, 1 resimden 1.
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
    FixBot'a Sor
    Yorum Ekle
  9. HMDX Chill Charging Port Replacement, Desolder the Charging Port: adım 9, 2 resimden 1. HMDX Chill Charging Port Replacement, Desolder the Charging Port: adım 9, 2 resimden 2.
    • Using a soldering tool, desolder the charging port from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Jourdan Holubasch
759 İtibar
7 adet Kılavuz yazıldı
Ekip
EWU-Giguere-S16S1G1 EWU-Giguere-S16S1G1 üyesi
Community
4 Üyeler
1Rehber Yorum
I have the charging port removed. Where do I find a replacement??
Aaron Hughes - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 24
Her zaman: 757
