Giriş
When the HMDX Chill is not functioning and all other attempts at fixing the issue have been made, the issue will most likely located in the motherboard. This guide will show how to locate and replace the motherboard of the HMDX Chill.
Neye ihtiyacın var
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
Neredeyse bitti!
Sonuç
