Ana içeriğe geç
HP 14-dq5043cl Wi-Fi Module Replacement
Neye ihtiyacın var
    1. HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: adım 1, 2 resimden 1. HP 14-dq5043cl Wi-Fi Module Replacement, Lower Case: adım 1, 2 resimden 2.
      • For your safety, unplug all peripheries, discharge the battery below 25%, and power down your device before beginning disassembly.
      • Remove the two rubber feet on the lower case.
      • If you intend to reuse the rubber feet: Use a hairdryer or iOpener to lightly heat the feet to loosen the adhesive that secures them prior to removal. Take care not to stretch out the rubber.
      FixBot'a Sor
      Yorum Ekle
    2. HP 14-dq5043cl Wi-Fi Module Replacement: adım 2, 1 resimden 1.
      • Remove the six M2XL6 Phillips screws that secure the lower case.
      FixBot'a Sor
      Yorum Ekle
    3. HP 14-dq5043cl Wi-Fi Module Replacement: adım 3, 3 resimden 1. HP 14-dq5043cl Wi-Fi Module Replacement: adım 3, 3 resimden 2. HP 14-dq5043cl Wi-Fi Module Replacement: adım 3, 3 resimden 3.
      • Insert a nylon spudger into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Remove the lower case.
      FixBot'a Sor
      Yorum Ekle
    1. HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: adım 4, 2 resimden 1. HP 14-dq5043cl Wi-Fi Module Replacement, Wi-Fi Module: adım 4, 2 resimden 2.
      • Remove the single M2x6.5 screw that secures the Wi-Fi module.
      FixBot'a Sor
      Yorum Ekle
    2. HP 14-dq5043cl Wi-Fi Module Replacement: adım 5, 1 resimden 1.
      • Use the pointed end of a spudger to lift and disconnect the two Wi-Fi module coaxial connectors.
      FixBot'a Sor
      Yorum Ekle
    3. HP 14-dq5043cl Wi-Fi Module Replacement: adım 6, 2 resimden 1. HP 14-dq5043cl Wi-Fi Module Replacement: adım 6, 2 resimden 2.
      • Pull the Wi-Fi module directly out of its socket to remove it.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Tristan Virgo
564 İtibar
5 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 219
